How can i add drivers after install os
How can i add usb port driver
    Problem Solver:
  • 11 Answers
After you install OS, US drivers are automatically installed (for xp etc)
Posted on Nov 26, 2009
Downloaded drivers for a new Samsung M2830DW and will not print. Computer does not recognize printer. Help???
Dear
Some times the front usb port arnot work. try to connect the /replace the usb cable to the usb port mounted on motherboard(back side panel of pc), It also may happen the usb port may disabled due to virus. Also you can unistall the driver during power OFF of the printer after uninstall successful power ON the printer, it will show NEW HARDWARE FOUND at the right right bottom of the pc screen ,If you OS is win 7 and connected to internet the driver automatically installed, otherwise you can load the driver cd and install the driver.
Also it can be checked at control panel-add hardware.
Thanks.
Feb 26, 2015 | Samsung Office Equipment & Supplies
I have loaded USB 2.0 Driver but System could not detect that USB 2.0 Port when I connect USB 2.0 device to all six USB Port. I am having DG31PR Motherboard. I checked in BIOS setup. High speed port enable...
You have not mention what Operating system is on your PC.
For Windows OS XP, you just have to install at least XP Service Pack 2 or higher... and the USB 2.0 ports will function. For Vista & Win 7 OS, the USB 2.0 drivers is in the Operating System when you install Windows.
Hope it helps.
Jul 13, 2011 | Intel DG31PR Motherboard
My USB ports won't work on my gigabyte MA69VM-S2 mobo with win7
Unlikely to be issues with the OS. Have you recently upgraded to Win 7 from Vista or XP? and did the USB ports work with this OS?
Do ALL usb ports fail or is it just one or two and are these the front USB's or rear USBs?
Dec 29, 2010 | Gigabyte GA-MA69VM-S2 (rev. 1.0)...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Cant install my hp deskjet 3325 printer to the windows 7
At this time, a full feature Windows 7 driver solution is not available for your product.
Follow the below steps to install your printer in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select Deskjet 3600 and then click Next .
  9. In the message window, click Finished .
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
How can i install in on my computer
The computer must have a usb port before you can install the MW-3805 (128 MB) MP3 Player. Also the OS musthave the usb Driver for the USB Port. Insert the MP3 Player into the USB port and the computer is surposed to automaticaly identify the Player after few seconds. If the OS has a compatible driver the driver is loaded and your MP3 is ready for us. If the OS does not have a compatible driver, load the driver CD that came with the device when prompted. when the diver is loaded the mp3 will be ready for use.
Dec 27, 2009 | GPX MW-3805 MP3 Player
USB recognizes it, but not the OS. I get no drive
Hello, nkhamo
Now, when you say USB recognizes it, do you mean you see the drivers being installed? Because if you are the OS is recognizing something has been plugged in.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all periperials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnection after installing drivers.
Its important to recognize the os you have. You'll find that information by clicking on Start Menu > Settings > Control Panel > System.
After doing this update, reconnecting the hard drive via USB Port.
Good luck, jasahasch
Aug 13, 2009 | Western Digital My Book Home Edition 500...
Possible usb malfunction?
hi,
well xp is a better OS than 98 ( i think) ...
few things you should know that xp is pre-installed with lotsa drivers..but on the other hand 98 isn't .. so each time you put in a USB device you need to install the driver for that device( eg your camera, pen drive etc...) . this drivers would be there accompanied with your device.
hope it helps
regards
bzoy
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
702 people viewed this question
David Payne
David Payne
