Back to:
Tags:
IBM 4232 Matrix Printer
IBM 4232 Printer Problem
By Pasty - usenet poster
My company recently purchased an IBM 4232 dot-matrix printer. Supposedly it
was new, but we bought it cheap off Ebay so we can't tell for sure. We got
the printer and set it up here, and the panel display said it was performing
some startup diagnostics. Then we ended up getting "042 Machine Error".
We've been talking to the gentleman who sold the printer, but I'm skeptical
that its going to get us anywhere. Before we tell the guy to screw it, take
the machine back, and refund our money, I'd like to know if there's anyone
out there who can suggest possible solutions to this problem, or what we
could be checking to find out the cause.
Any suggestions would be greatly appreciated. Thanks!
Al
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Melissa
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
An 042 machine check is pointing to the form feed mechanism (forms
motor or system board). Here's what I'd do:
(1) Remove your forms module (probably an F2).
(2) With power off, open the top cover and move the large white forms
gear on the right side back and forth. It should move easily. If it
does not, you've got a mechanical problem (something jammed in the
gears or a broken gear).
(3) Re-install the forms module, making sure that you pull it all the
way forward. Move the white forms gear back and forth again. You
should have a bit more resistance than before, and the tractor bars on
the forms module should move with the gear movement. If you can't
move the white gear, you have a broken forms module.
(4) If everything checks out to this point, load paper and power on
the printer. If you get the 042 check again, either the forms motor
or the system board is bad.
Rick Ekblaw
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on IBM 4232 Printer Problem:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
hp photosmart c4480 will not connect to pc
Printers
The monitor that lets me know when ink tanks are low, or...
Printers
I keep getting a message on my Lexmark all in one P4350...
Does this require a firmware upgrade?
Our trusty 4232 has recently started to give a forms jam...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
