Question about JVC TH-C60 System
Can't get jvc th-c60 to turn back on
It lost power one day and now will not come back on. Tried to unplug it and plug in to different outlet but still won't work. It is only two years old.
  • 547 Answers
Check fuse
Posted on Feb 19, 2009
How do you connect a jvc th-c50 hometheater to you tv?
By comparing the unnamed TV's manual and capabilities to those of the TH-C60.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-C50J-Home-Theater-Systems-manual/id/318ci575/t/2/
Jul 06, 2011 | JVC TH-C50 System
We had 52' HD JVC Tv for 2yrs and the other day, the power button was flashing and didn't have a picture and now it won't even turn on. We tried unplugging it for a while and still nothing
This can be a power problem it can be a power problem inseide the tv or a power distribution problem from your power outlets. So before you send this to a repair shop you can try to plug the tv to a different outlet by using an extension cord. I understand that you have tried to unplug the tv for several minutes but plugging the tv to a different plug in can make a difference.
Sep 09, 2010 | Televison & Video
JVC TH-C60 DBS stopped working
When you say the "TV side" you really mean the Cable or Satellite Box audio, right? There's no digital optical connection intended for the physical TV.
I hope you're not really looking directly into the cable with your naked eye. A safer way to visually check for the presence of red laser is to hold a thin piece of white paper up against the cable and observe the spot.
With your remaining good eye, look INdirectly or hold a thin piece of white paper in front of the the optical port on the JVC to see if there is a visible red glow. Most likely the cable itself is the problem. Make sure it has large open loops rather than tight bends throughout its routing.
Mar 24, 2010 | JVC TH-C60 System
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
JVC TH-A30
Unplug your system from AC power.
Let it sit for a few minuets (there are capacitors inside of the unit that stores a small amount of power that needs to be discharged, which they will do if the power plug is not connected to the wall outlet). Then plug the unit back into the wall outlet and insert the rental dvd. This should allow the unit to play the dvd now.
Dec 17, 2007 | JVC TH-A30 System
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
JVC TH-C60 System Logo
441 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
