Question about LG WM2277H Front Load Washer
HOW DO I REMOVE THE BEARINGS OF THE REAR OF THE DRUM FROM A LG FRONT LOADER
  • ianthetiler Feb 20, 2009
    you are wrong i spoke to a service person they are a servicable item
  • 188 Answers
You can't since these bearings are pressed in at the factory and are not serviceable. You would need to replace the tub's rear shell assembly.
Posted on Feb 19, 2009
Have a lg direct drive front loader model wd11020d makes a knocking noise and after a while an Le error comes up, pulled the back of all looks in good condition
Open front door. Pull push on inner drum and see if it wiggles independent of outer drum. If it does, then the knocking is a bad bearing or spyder(part that hold drum to bearings). If inner tub is tight, then I'm not sure issue. LE error is a Rotor Position Sensor error.
Jan 30, 2017 | LG Washing Machines
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 12, 2014 | LG WM-1832C Front Load Washer
LG WM2032 HW making noise, drum moves to much, belive the bearings are shot, but it also leaked the water out of the drum when is shut down. Can just the bearing going bad cause this are is there an...
You are probably correct. If the inner drum is loose and sloppy you probably have collapsed bearings and seals.
What can also happen is that the inner drum can make contact with the outer drum and wear through it. This could be the reason for the leak.
Unplug the machine at the wall. Remove the 2 screws under the rear of the top. 'Bump' the top to the rear to unclip it, and remove.
Remove the back panel to inspect the rear of the drum. This will expose the outer drum.
If the bearings and seals have failed, you have quite a large job ahead of you.
A holed tank is another level of expense. It may be cheaper to replace the machine...Get quotes.
Good luck....Nomess
Sep 06, 2010 | LG WM-2032H Front Load Washer
Where might I be able to find the rear drum bearings?
first off, what model dryer do you have? More than likely your rear drum bearings are towards the back of your dryer, but they may also be drum rollers. you need to access you dryer from the front on most models.
Jan 14, 2010 | LG WM-1485FHD Front Load Washer
Drum bearings replacement
go to this site...
www.Howthingswork.com
it is amazing what you can find there
Jul 31, 2009 | LG WM1812C Front Load Washer
Washing machine, bang crash
It sounds liek a shock/support is broke. Remove the lower front panel after you UNPLUG the washer and you might be able to see what is wrong.
Hope this helps.
Thanks
Vic
May 11, 2009 | Washing Machines
How do you remove drum from outer casing and replace bearings
dissasemble front of machine undo rear pulley I suggest you buy a tool called the Tony tool which is made to install and install the bearings correctly
Feb 21, 2009 | Maytag MAH21PD Front Load Washer
Replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Dec 02, 2008 | LG WM-1832C Front Load Washer
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
LG WM2277H Front Load Washer Logo
232 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
