Question about HP ScanJet 5300C Flatbed Scanner
Hp5300c scanner-can't use HP software on new PC (XP Pro SP3)
I have installed my HP5300C scanner on my new PC (2.66Ghz quad core, 4Gb ram, XP pro SP3) and it works fine with the scanner and camera wizard but when I try to run the HP scanner software (which I prefer to use) the scanner window comes up but just hangs. I have tried uninstalling, reinstalling software, same with drivers from device manager, I've tried v3.0 from the original disc and v3.04 which are the latest drivers, installing software 1st then hardware and visa versa. Each time uninstalling drivers and software fully. Can anyone help?
  • 28 Answers
Are you using the software from HP? It sucks. If the HP software is not working correctly, then Use the one provided my your operating system works great. Go your Control Panel, Printer and other Hardwares and click Scanners, make a shortcut to your task or start menu and Scan Away. For Faxes, etc. import in outlook or other email client, etc.
Posted on Feb 26, 2010
Mac pro not turning on
WOW, could be a ton of different possibilities.
I'd start with the power supply.. Most common to die.
Might cost you a arm and a leg. not sure what power supply the mac pro takes - Good luck - Vote yes if this has helped you..
Mar 21, 2014 | Apple Mac Pro 8-Core Two 2.8Ghz Quad-Core...
Fiteed new quad core CPU and 4gb of Ram, when started up getting no signal detected on the monitor. Can anyone help?
Let's back up a second.
A) What HP model is it? (P/N. Product Number. Back of desktop computer tower)
B) What model number of Intel quad core is it?
C) What are the manufacturer ID number/letters on the ram memory module/s?
I need to know what Northbridge chip is used on the motherboard, to know if it will support the particular Intel quad core you're trying to use.
This I can hopefully obtain from HP Support, by looking at the specifications for the motherboard.
(This technology does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge chip is part of the motherboard chipset.
So aptly named, because on a desktop computer motherboard it sits to the 'North', for one.
(Under the Processor)
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
AGP and PCI-Express are high-speed graphics technology.
A graphics card plugged into a PCI slot, and Integrated Graphics, is Not high-speed graphics.
The Southbridge chip handles the slower capabilities of the computer.
Motherboard Diagram;
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
List of Intel Chipsets, and more specifically the one's that can handle Intel quad core processors,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_chipsets
Secondly;
Make sure the Ram Memory you installed is Compatible.
If the motherboard supports 4GB of ram, make sure it is in the correct ram slots if using two sticks of ram, or four sticks.
There HAS to be a ram memory module ('Stick') in Slot 1. (DIMM 1)
EACH ram memory slot has a Maximum Amount.
For example if there are 4 ram slots, and the Maximum Total Amount of ram memory is 4GB, each ram slot may have a maximum of 1GB.
It may, or may not be that you can use Slot 1 and Slot 2, and use two 2GB sticks.
Third:
Always go slow when upgrading.
Install the Processor first, boot the computer up, see how it works.
THEN shut the computer down, unplug from power, observe Anti-Static Precautions, and install 2GB of ram memory.
Works?
Install the other 2GB.
BIOS has to recognize the changes.
Fourth:
Are you sure your Power Supply is adequate to support the quad core, and the added ram memory?
Post back in a Comment.
Regards,
joecoolvette
Jul 24, 2011 | HP Computers & Internet
Can I make my HP5300C Scanjet operate on windows 7
Use windows7 Prof or Ultimate
Install XP-mode
Working in XP-mode
Install the sj664 HP software.
Though the USB device HP5300C can be found, the HP scanning software will not yet find the scanner. Because the scanner is shared between W7 and XP.
On the XP-mode taskbar disconnect the USB device HP5300C.
Then start HP Precisionscan and the scanner will function as before.
It is clear why HP does not advise this simple procedure.
Just because they did not present any clue triggered me to try it once more.
Jan Wondergem
Aug 22, 2010 | HP ScanJet 5300C Flatbed Scanner
HP5300C Cannot Find Scanner message from PrecisionScan SW
Does it show up in your hardware profiles? What does it say on details when you right click the scanner? When you installed the driver, was it before your plugged in the USB? You may have to uninstall and reinstall it again, this time use the one from HP's website with any patch if applicable.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=sj664en&lc=en&cc=us&dlc=en&product=58381&os=228&lang=en
If you have successfully used it in the past, follow the install prompts and restart.. instead of using the products software, use Windows included scanning program which is much better than the proprietary one designed by HP. As long as you have the proper driver installed your system will know how to apply it.
Feb 25, 2010 | HP ScanJet 5300C Flatbed Scanner
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
Windows explorer not initiated at startup and hangs the system,
I had this XP problem with Norton recent after SP3 got on.
Clean install and no antivirus, straight afterwards a bootable CD with SP3 then I replace already removed Norton with Avast virus scanner.
Superfast, all problems I ever had gone. Likely the scanner.
Apr 14, 2009 | Microsoft Windows XP Professional
Multiple Boot on a Dell Inspiron Laptop
Invest in a couple USB drives and install the other os's on them. before you boot up plug in the apropriate drive and boot from it. Thats less complicated and painful to me
please, Let me know :)
Dec 24, 2008 | Dell Inspiron 6400 Notebook
Hpscanjet 5300 software problem
I'm sure SJ664EN.EXE is just the installer. Once installed there may be several applications, with one of their files named HPPRSCAN.EXE, just look in the Windows programs menu for HP.
Oct 10, 2008 | HP ScanJet 5300C Flatbed Scanner
HP ScanJet 5300C Flatbed Scanner Logo
313 people viewed this question
Seeker5211
Seeker5211
