Question about Intel S5000VSA Motherboard
Intel Server S5000VSA gives 3 beeps and no BIOS display.
Can I use Kingston 1GB RAM KVR667D208F5/1Gin 555-11-80 1.8v in Intel Server Motherboard S5000VSA.
My sata hard dist not support in intel server board
plz give me bios setting.
Posted on Sep 10, 2010
  • 3 Answers
1) If RAM is absent or dead then computer gives 3 beeps.
just remove u r RAM place it in other socket, if you face the same problem than your RAM is faulty.
2) if RAM is absent or dead than your PC will not start.
Posted on Feb 19, 2009
  • 837 Answers
According to the following document (pages 14-19) published by Intel .. That memory module is not listed as tested/working with that board.
1 LONG BEEP, 2 SHORT BEEP
1 long, 2 short Failure in video system: a checksum error was encountered in video BIOS ROM, or a horizontal retrace failure has been encountered
Apr 29, 2014 | Gigabyte Motherboard GA-H55M-UD2H Core...
No bios display gives 3 beeps, already replace with known working memory. but still have the problem. please help
We do this all the time. If you're saying that you have tried it with a known working memory modules then most likely you will have to replace the motherboard of the system or you can reseat the jumper of the motherboard and try it again, if it will still not work then you have to get the motherboard replaced.
May 11, 2010 | Intel S5000VSA Motherboard
I added NEW rams to my intel SE7505VB2 Motherboard and when i start the Server i hear beeps in the form of 4-3-1-3 with Blank Screen when i googled the beep codes for Phoenix BIOS i got: Initialize the...
it means you are traing with diffrent RAM module
this is your Sever Moduals
Memory Memory Type DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 8 GB
or go to link u will find all the details of your server
http://www.dealtime.com/xPF-Intel-Server-Board-SE7505VB2
Hope this helps you in your troubles!
If it does, be sure to give me a thumbs up.
Apr 24, 2010 | Intel Server Board SE7505VB2 Motherboard
check ur ram nd cmos battery remove ram nd take a eraser rub the down portion of ram clean it and insert it again..
Sep 06, 2009 | Intel S5000VSA Motherboard
I HAVE 2 MOTHERBORD 3 BEEP PROBLEM,CAN I SLOVE THIS PROBLEM P HLP
check the memory cards or video cards if properly seated in the slots
Aug 10, 2009 | Intel S5000VSA Motherboard
Case fan runs at high speed all the time not
There should be a fan settings area is your system bios. Make sure it is enabled for adjustable speeds if you have adjustable speed fans installed. Hope this helps.
May 01, 2009 | Intel S5000VSA Motherboard
3 Beep sounds-No boot
As you probably know 3 long beeps on an Intel motherboard is memory failure. Even if RAM is good your Motherboard may have problems in reading your ram module.
If you are using a PCI or AGP video card try also removing and putting back video card, video adapters use shared RAM and can give you troubles with RAM.
Always perform all maintainance on motherboard with power unplugged and avoid to touch contacts and circuits with your finger.
If the 1GB module is new, verify with seller that your motherboard support this memory, some motherboard do not support double density RAM.
Aug 16, 2008 | Intel Desktop Board D845GLVA...
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Intel S5000VSA Motherboard Logo
1,646 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
