Question about Yamaha RX-V461 AV Receiver
My Yamaha AV Rx-V461 not turning On
My Yamaha AV Rx-V461 bought just 9 months back. It was working absolutely fine even during summer when lot of overheating happens then it never turned-off itself. But surprisingly, 3 days back, in this cold weather, without much heating, after playing continuously for 1 hour, it suddenly turned-off by itself. There was no burning smell or spark or anything unusual which could be observed. Even after leaving it off and unplugged for several hours, 3days, it is not turning on. As per its manual, for any reason if protection circuit is activated then system should be unplugged for 30 secs and then it can be used normally. But this has not happened. I was happy to assume that there must be a fuse behind which would have blown, but shockingly there is none.
can anybody help?
Prashant
  • prashants3 Feb 20, 2009
    Thanks Mr Dan for advice. I have sent it to the service center yesterday only (it had one year warranty period). Today I got a call from service center that it has been repaired & can now be collected back. On asking what had gone wrong, I was told that a thermal fuse attached with main transformer had blown and was replaced.
    For this repair I would have spent money equivalent to about 60 USD, had it not been under warranty. As this amount is not small for me (if required to be spent quite often beyond warranty period). There is hardly any cost of that fuse, whole amount is mostly for service.
    I fear if this problem happens frequently, I will not be able to send it to service center. Can you or anybody help me in getting service manual of this model? Or at least, can someone tell me how to open (& then close it properly) for changing the fuse next time if required. I am myself an Electronics Engineer and can do this if I come to know the proper method of opening & closing it. (I can see all the screws but there may be a special procedure for opening & then closing also).
    Thanks & Regards!
  • prashants3 Feb 21, 2009
    Thanks again Sir,
    But the service technician told me that he has replaced ONLY the fuse which is (somehow) attached to the transformer. Cost of this fuse is only Rs 5 (10 cents). ALSO he took only few minutes to do this job. That is why I was tempted to prepare myself to do this if required in future.
    My power strip already has the surge protector. But, since you have pointed out, I shall change it to a better quality.
    May I still request you or anybody help me in getting service manual of this model or tips on how to open (& then close it properly)
    Regards!
    Champion:
  • 287 Answers
These have regulator ic issues, Mainly the regulators for plus and minus 5 volts and 12 volts. All can be checked off the main connector coming from the top regulator board. Lately I see alot of theplus or minus 12 volts go bad. When one fails a plus 12v may read 9 or 10 volts only for example.
Posted on Jul 21, 2009
  • 4,234 Answers
Most units have a 1 year warranty, so be careful in opening up the unit. That being said, the protect message indicates that there is a problem in the final output stage of the amplifier. This can be as simple as a poor connection at the voltage regulators that will force the unit into an offset condition or more complex like shorted output transistors. and drivers. Since this unit is still relatively new, I would suggest that you investigate its warranty status first. Let me know what you intend to do.
Thanks,
Dan
Posted on Feb 19, 2009
  • ABRsvcs Feb 20, 2009
    Unfortunately, you can not change this fuse as it is an integral part of the power transformer. In fact the entire trnasformer was replaced. This usually fails because of a power surge. I would recommend that you purcahse and use a power strip with a surge protector for this unit. That should prevent this from happening again.
    Dan
What are the surround sound settings for a yamaha rx-v461?
It has many, depending on the your speaker configuration, the source hardware and the source material...
Read the manuals...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V461-Receivers-manual/id/2526ci760/t/2/
May 07, 2011 | Yamaha RX-V461 AV Receiver
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
I own a Yamaha RX-V461 and since making a few changes, new Bravia TV and BLu-Ray DVD player, I no longer jhave sub woofer output. I bought a new sub woofer cable and even bought a new Polk 8" 300watt sub....
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Jan 24, 2010 | Yamaha RX-V461 AV Receiver
Need remote control code for Samsung BD-P1600 on a yamaha RX-V461 remote
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V461_U_en.pdf
this web page has complete manuel for your yamaha RX-V461 home theater system they list code for samsung tv as 30739
press dtv button
press code set button
enter five diget code any questions refer to online manuel good luck ron
Dec 12, 2009 | Televison & Video
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Dec 01, 2008 | Yamaha RX-V461 AV Receiver
I have a RX-V461 AV Receiver for my Samsung HDTV.
I don't have manual here, but try to go to Setup menu / Speaker setup / Manual Setup / Config and check if rear speakers are NOT set to None.
Nov 19, 2008 | Yamaha RX-V461 AV Receiver
Yamaha RX-V461 AV Receiver Logo
390 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
