Question about Acer Aspire 5610-4648 Notebook
Acer aspire e380 stuck
The pc is stuck on the acer "loading" screen where it has the options to press del or f12
but it doesnt let me press anything on the keyboard
can anyone help?
i recently started using a new mouse with it
  • 544 Answers
Hello thank you for using Fixya.com.
first try to take off the battery and turn off your laptop 5-10mins.....
and open it but if the same message will appear then your unit encountered some technical and software problem like infected with virus.
i advice you to reformat your unit as soon as possible...
thanks.
......your rate on Fixya are much appreciated....
Posted on Feb 19, 2009
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
May 25, 2013 | Acer Aspire 5742Z-4601 : 2GHz Pentium...
My computer turns on but is stuck on the acer screen del: enter setup and f12: boot menu are there but keyboard won't respond I've tried everything
First unplud everything except the monitor and keyboard from the system. This can help to narrow down the problem. If it boots after doing this then one by one plug everything back in until you find the problem device.
Also try leaving it on the Acer screen for a while to see if you eventually get an error code. You might even have to let it set there for 30 minutes or so.
Jan 08, 2013 | Computers & Internet
When its switched on it doesnt boot, just goes to the acer splash screen that says 'Del to enter setup" and "F12 for setup'. I think it was switched off with a usb memory stick 2.0 connected,...
Have you gone to 'setup' using F12?
If you can get into Setup you should be able to change boot options to boot from fixed (hard) disc. Unless the hard drive has been damaged or formatted this should work.
Jan 04, 2011 | Acer Aspire™ T180 PC Desktop
I have an acer aspire, after switching off last night and turning back on, I have a screen del: set up or f12: boot, nothing happens when I press either, have had to hold in the on off button a few times...
First reattch your mouse and keyboard cable connection to cpu.
Then check if still same then open cpu cabinet.
Refix RAM memory.
When cmos cell is gone this issue occurs so change cmos cell .
Pull cmos cell from motherboard for 10 minutes then refix into it.
Reattach ATX power connctor from smps to motherboard.
Reattach processor and its fan.
then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 10, 2010 | Acer Aspire T310 PC Desktop
Stuck an dell logo screen f8 doesnt work
check if F2 works. also check if F12 works. if all fails then some of your keyboard keys might not be working. if you are stuck in dell logo the screen might asking you to press anything which will allows you to continue.
Nov 04, 2009 | Dell Dimension 4400 PC Desktop
Acer computer is frozen on screen which reads press f12 or del to enter setup. when computer comes on it does not beep so i cannot use keyboard all the lights on the keyboard aare off. HELP!!
From the description you are giving, it appears that the system is not detecting a bootable hard disk drive. Hold the power button on the system till it powers off. once system is off, try the following:
  1. Ensure no floppy diskette is in the A: if system has a floppy drive
  2. Disconnect all external items (Printer, scanner, network connection) leave only video and keyboard connected to system.
  3. Try powering system on again
If the system gives the same message, try rebooting and pressing F12 ONCE at the ACER screen and see if you can get a 1 time boot menu. If you can get the boot menu, select CD-ROM, and put you WINDOWS CD in the optical drive, see if system will boot to the CD. If you can, then at the first prompt, press R to enter recovery console, and see if you can run the command CHKDSK /R (then press enter)
If chkdsk runs, then reboot and see if the error has gone away. IF you cannot run CHKDSK then the hard disk drive has likely failed and will need replacement.
Nov 01, 2009 | Computers & Internet
Acer Aspire E571, stuck on "ACER" screen
Have you tryed unplugging the HD and seeing if you can access the cmos?
Dec 06, 2008 | Acer Aspire 5610-4648 Notebook
My PC was unplugged before powering down it is an ACER, all that comes up not is DEl TO START UP AND F12 TO BOOT NETWORK...MY PC will not recognise my keybaord
Hi Tilley;
Power Off your PC
Remove Keyboard
Power ON your PC, do you see "No keyboard detected"? anyways
POwer Off your PC again
Now,insert back your keyboard, POWER ON and make sure you see 3 lights blink in your keyboard
better yet, use your keyboard on another PC just to make sure its working.
Hope this helps, i often do this procedure when my keyboard doesnt work...
Jun 21, 2008 | Computers & Internet
Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
Jan 09, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 5610-4648 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
