Question about Rockford Fosgate Power 1000BD Car Audio Amplifier
I have an old punch power 1000a2 and 1 channel blew...i wonder how i can dis-able thar side of the board so i can use the other channel?
  • Erik Anthonsen
    Erik Anthonsen May 11, 2010
    you should be able to just use the terminals that arent blown!
My jmc7000 jenn-air blew a circuit breaker. No power to the unit. There is power to the recepticle. I'm wondering if it blew a circuit breaker, does that mean the problem is most likely a big problem...
Yau say a few conflicting things. First you wonder if it blew a breaker, and then say you have power to the receptacle. If you have poer to your receptacle your breaker if not tripped. There are NO breakers Inside of the Microwave. Only 1 time fuses. So, if your init is dead it has probably blown a fuse inside of the unit. If that is the case. Probably shorted HIgh volt capacitor would be my first guess. If it is jsut dead. it can be other things than just a blown fuse. bad thermal protectors, bad low voltage transformer on main circuit board. Burnt wires. Anything that will cause it to lose power inside the unit. From bad parts to bad connections.
Aug 16, 2017 | Jenn-Air JMC7000 Microwave Oven
Was hooking speaker wires up while unit was on ( my mistake)was hooking last chnl pos first it popped flashed back side near power supply blew 2 fuses one on bot board one on what I will call power supply...
You have taken out 1 or 2 channels that are ic driven, the relay is sensing a short in 1 or 2 channels and will not engage until it is repaired. This will need a service shop that can deal with the complexity of finding the problems.
Dec 28, 2010 | Onkyo TX-SR501 Receiver
Vsx-816-k left channel cuts in and out.
You likely have a cold solder connection on the circuit board. Inspect the board for loose connections for the left channel - use a non-conductive pointed object and poke the board on several places while the unit is power-up. Be careful not to get electrocuted. Compare it to the right channel circuit - they are almost identical. If the unit recovers the left channel while poking, then you have found the bad connection. Re-apply solder to that junction - make sure you've dis-connected the power and dis-charged all caps before you touch and repair the circuit board.
Nov 09, 2010 | Pioneer VSX-816-K/S Receiver
Due to no electrical safety fues on the amp my channels burnt up because the speaker blew can i buy channels for my amp or do i throw it away I own a punch 301s 900watts
your amp can be repaired by a professional to hard for someone without electronics training. you may find it is to expensive to repair. new will probably be your best bet.but do find out about repair before buying new. I have a local shop here that has a 60 dollar fee to look at it then if parts are needed they have an hourly rate plus parts. good luck
Apr 23, 2010 | Rockford Fosgate Punch 301S Car Audio...
A powerful storm blew my neutral wire connection off, up by the roof. It fried the washing machine's transformer. A capacitor next to the transformer looks like burnt toast. I wonder how much more damage...
You will need to replace at least the circuit boardin the washing machine. When the neutral come loose the voltage usually gets low on one side of the panel, and gets very high on the other side, and this high voltage has destroyed the circuit board, and transformer. As to the price of the repair, i feel like it would cheaper to repair than replace.
Mar 17, 2010 | GE Profile Prodigy WPSE4200A
Have Sharp 13" tv about a year old. Only arrow on remote that works is volume up. Volume down and channel arrows do not. Power and punch in channel numbers do work
If you can get the remote apart try cleaning the contacts on the inside of the touchpad and on the circuit board with alcohol and cotton swabs.If this doesn't work you will need a new remote.I assume the buttons on the TV itself work.
Dec 01, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Mar 16, 2009 | Bryston 4B SST 2-Channel Amplifier
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Rockford Fosgate Power 1000BD Car Audio Amplifier Logo
502 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
