Question about Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television
I cant get the fans to turn on!!!!!!!!!!!
I have a pioneer PDP-503CMX plasma 50".I can not get the fans on and after about 1hr. the top of the tv starts to turn green then if i turn it off and let it sit for some time its good for 1hr. again! So i know it has to do w/the fans not turning on.Where can i find heat sensors for the fans???????
Thanks,jon.
  • azstrider Apr 11, 2009
    Do others with this problem have their small top corner fans working
    correctly? Is there a way to set these to run continuously since this
    may be related to a heat related problem (green/grey sparkling on top 1/3 of screen) with the display due to heat
    build up.
  • 5 Answers
Call up the 'Integration Menu" - the fans can be switched between 'auto' and 'full speed'.
To do this switch the display into standby. If the standby light flashes 4 times it is indicating a fault in the Thermal Sensor Assembly which will explain why your fans aren't working. With the display in standby press the menu button and within 3 seconds press the power button. The display will turn on with the integration menu. Select the option tab and scroll down until you see 'fan control' - press 'set' to toggle between 'auto' and 'max'. When you select 'max' the fans will run at full speed within a few seconds. The fans are a bit noisey at full speed so you may want to look into replacing the sensor eventually.
Posted on Aug 04, 2009
I have a pioneer plasma that keeps telling me
Just check this site named Electro-help. Almost all plasma TVs will have the same confuguration of boards and functions. You can see so many faults related to plasma TVs there. As your problem post is not clear to understand about the problem you faces with this TV. That is why I draw your attention here. Just check this link, and select the site.
Jul 11, 2012 | Pioneer PureVision PDP-503CMX 50 in....
Trying to figure out the voltage for power supply on a pdp-503cmx and cant figure it out i think it is supposed to be at 250v but i only get 122v not sure i need help!!
It sounds like you have the notorious Pioneer power supply issue. Pioneer had been replacing these free of charge. You can contact Pioneer and attempt to schedule an in home swap free of charge. While the 503CMX was on the recall list, i think the warranty extension has expired on all affected models but it won't hurt to call Pioneer and ask if they'll pay for the repair........
Jun 20, 2011 | Pioneer PureVision PDP-503CMX 50 in....
Problem with Pioneer PDP-5080HD 50 in. plasma television The power turns off every 15-20 minutes
hi,
There is some over heating problem in you television. there will be two fans inside you television. if any of the fan get faulty then that section of you TV will get over heated and will shut off by itself preventing from further damages. Check the two fans. For that you have to open your TV.
ok
Jun 07, 2011 | Pioneer PDP-5010FD 50 in. Plasma HDTV
Need a remote control for Pioneer model PDP-503CMX
Here you go sir/mam
http://parts.pioneerelectronics.com/part.asp?productNum=AXD1459
Sep 24, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I heard a pop from my tv and then the tv didn't work
Anything is repairable as long as the screen isn't damaged.
The sound you heard is most likely was a capacitor that just went dead.
Solder in a new capacitor should fix the problem. It would most likely be on the power supply board somewhere.
You'll need the Service Manual for parts list, diagrams, and schematics. Here's one place for that:
http://www.manuals-in-pdf.com/advanced_search_result.php?keywords=pdp-503cmx+service+manual&forward=plist
Any other questions just ask.
May 10, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Media Receiver
There should be fans inside this unit too. open the top cover and see where the noise is comming from. I am sure you will find it. Good Luck
Mar 21, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PureVision PDP-503CMX 50 in. HD-Ready Plasma Television Logo
585 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
