Question about Siemens SpeedStream 5260 ADSL LAN Modem p/n 060-5260-003 (SPEEDSTREAM5260)
My modem is not working, all the light are solid green but is not conecting to the internet.
Click the Edit menu, click Find, then click People.
Select the Internet directory service you want to search at the top, type in the person's name, then click Find Now.
Posted on Feb 19, 2009
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Dsl light goes beyween blinking green, then goes solid red, then back to blinking green. Cannot connect to internet anymore.
The modem cannot get a signal from your service provider. The DSL light is an indicator if your modem is communicating with the network of your service provider. DSL light should always stay solid green. Try contacting your service provider. It might also be an indication of a bad modem.
Aug 31, 2011 | Arris 221002 DSL Modem Southwest Region...
Westwall modem Internet is solid red light
If the internet light is red, it means that the modem cannot get an ip connection from the ISP.
If your ISP has a PPPOE connection, most likely, the PPPOE password is not correct.
To ensure your settings, access the modem through a web browser. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, you will need to reset the modem. Just hold the reset button for 30 seconds. Then turn it off for 1 minute.
Try again to access the modem, under Configuration, click Edit beside My Connection. Type your ISP username and password then Save.
Hope this helps! Good luck!
Jan 24, 2010 | Westell Wirespeed LiteLine 6100...
2Wire 473 router problem
Take the modem and plug it into a GFCI outlet. You can find one in the bathroom or the kitchen.
If the power light comes on solid green and the dsl comes on red then the modem is good. Was it plugged into a power strip by the computer? If so, plug it straight into a wall outlet.
If the power light comes on solid red then the modem has hardware failure. I would contact your ISP and have them replace it if it is still underwarranty.
Mar 23, 2009 | 2wire (1000-400108-001) Router
Internet stopps working
if you have router connected to modem
turn of modem and router, unplug the power plug and wait atleast 25 sec
after 25 sec, power on modem and wait for all the lights turn solid green (power, wireless, internet)
then power on router and connect to modem
go to your pc and click Start>>>>RUN
type CMD
then command prompt will pop up
type ipconfig /flushdns then press enter
type ipconfig /release then press enter
type ipconfig /renew then press enter
Mar 20, 2009 | Intel D101GGC Motherboard
1st time installation: cannot install modem properly
Hey try this one, if doesn't work let me know. First you have to powercyle your modem - meaning turn it off for 10 to 25 seconds then power it up again. Then check status of the modem lights. It should all be in solid green. Else you have to check if cables are properly connected - Data cable (green cable) one end connected to the filter with labeled "DSL/PHN" or the one with monitor engraved, then other end connected to the green port on the back of your modem. Then check also connection of filter to walljack. After which check status of the lights. If still not all in solid green. Check devices near to your modem, these might be the reason for interference of DSL signal. Electronic such as monitors, speakers... must be 2-3 feet away from your modem. Check modem lights. If all in green, test connection. Also there should only be one phone jack connected to your DSL phone line.
Jan 14, 2009 | AT&T High Speed DSL Modem
Westell 6110, No internet light.
Contact verizon if they can replace the router becase the internet light should be green and flashing as you use the internet.
Dec 30, 2008 | Westell Wirespeed VersaLink...
Internet
Well, I understand that the modem is SS4100, which means ther are
5lights on it being, Power, Ethernet, DSL, Internet & Activity....
Note:The trouble shooting is done according to the Light Status on the modem.
1. No matter what the proble is, the first step is to Power Cycle the modem to eliminate the static on the modem(to switch it off and back on).
2. If the Power Light is anything other than a solid green, then the modem is fried(except the fact that the adapter is plugged and working).
3. If the Power is green and Ethernet is off, then check for the LAN cable at the back
of the computer if its connected to the modem.(It turns green if connected properly)
4. If the DSL light is anything other than solid green, then call up the ISP tech's to ask why the intenet is not working.
(make sure the DSL cable is plugged firmly onto the back of the modem and the wall jack)
5. If the Power, Ethernet and the DSL is green and the internet is not, the open up the Modem page(type 192.168.0.1 in the address bar and enter for the modem page), and cross-check for the username and the password. Save the changes and your internet is working!!!
6.  The Activity light usually blinks green and it does't have much to do with the troubleshooting.
The above are the basic troubleshooting steps.
Hope it solves your problem......
Dec 20, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Computers & Internet Logo
235 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
