Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
Canon Ixus 800 IS into webcam
How do I use the above mentioned camera as a webcam for MSN Messenger?
old marine
  • 2039 Answers
SOURCE: want to change the language
Make sure the mode dial is in playback mode and the camera is turned on. Press and hold the Func/Set button, then press the Menu button. This will bring up the language selection screen. Release both buttons and use the arrow keys to highlight the desired language. Press the Func/Set button to select.
Posted on Jun 20, 2008
SOURCE: canon digital ixus 700
I understand that it takes a maximum of 2GB. Still loads of photo/video capability. Don't make the mistake I did of buying a 4GB SDHC card for it. It won't take it.
Posted on Sep 28, 2008
  • 11 Answers
SOURCE: Can the canon ixus 80 is be used as a webcam?
It may be able to be used that way (but its pretty iffy)...you would have to have to have a computer with an RCA-type video in jack (or an installed TV tuner card with the same RCA-type video in jack).
And if you have that setup on your computer, then you could use the AV cable that is supplied with this camera to send video out (either what is being shown on the screen in shooting mode, or already taken pictures/videos in playback mode) to your PC.
You would then need to point whatever software you are using to broadcast your webcam stream to the "video in" jack as the source of your webcam video (if it even allows for that option).
If you can do all that, it MIGHT be possible, but its probably a pretty long shot.
Posted on Jul 26, 2009
BillB-SA
  • 2761 Answers
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • 102366 Answers
SOURCE: hi im using a canon digital ixus 9515 camera. can
This camera is designed to store images and videos to a memory card, not to stream them to a computer. It cannot be used as a webcam.
Posted on Jan 15, 2010
Unable to use my web camera in yahoo messenger and msn messenger inldy advise if i need to down load undate for drivers
Please, try to update your msn and yahoo version:
1. check your messenger version (same procedure for each): click on help>in drop down menu click on "about ...">it shows the messenger version.
2. Go to official site of each your messengers and see if the version you've got is outdated.
3. If there is a latter version of messenger follow these steps:
---go to START button, click on Control Panel>Programs>Uninstall a Program>Windows Live Essentials and uninstall. Then go to the official site, download the latest version of Windows Live Essentials and install.
---For Yahoo Messenger follow the same procedure as above, but instead Windows Live Essentials choose Yahoo Messenger. Then go to official Yahoo download website, download the latest version of messenger and install it.
4. Restart your computer.
It should work now.
In case it does not work, follow the same procedure as above, but now choose your webcam and uninstall it. Then go to this link: http://download.cnet.com/Veo-Mobile-Advanced-Web-Camera/3000-18489_4-62939.html
and download the driver, install it, restart the computer. It should work now.
Jun 18, 2011 | Veo Advanced Connect Webcam
My logitech webcam won't work in msn messenger....in messenger when i try to make a video call...it says I need to buy or install a webcam? what's the deal? heeeelp
Hi Marilyn,
Have you installed the Logitech Quickcam program? If you did then open the application and select the instant messenger(i.e. MSN, SKype, Yahoo) that you will be using the camera.
If you have note yet installed the Logitech Quickcam application then I suggest you disconnect the webcam and run the software first.
Oct 28, 2010 | Logitech QuickCam Communicate STX Personal...
Canon Digital IXUS 850 IS how to use as webcam?
The IXUS 850 IS is designed to store still images (and incidentally, videos) to memory. It is not designed to stream live video to another device.
I know that wasn't the answer you wanted to see, but there it is.
Sep 02, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Acer crystaleye webcam
You need to configure your MSN Messenger to use your webcam by going to options and select video or webcam preferrence.
Jun 09, 2010 | Acer Aspire One PC Notebook
How to get labtec webcam to work on msn live?
We couldn't start your camera device. Please check that your camera is not currently in use by another program, and then try again.
this is the error msn i get when iam trying to use my camera in msn messenger on all other i can use ? whats the reason ?
Oct 09, 2009 | Xirlink Promax Webcam
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
Yahoo messenger - Webcam is not connected
You cannot access camera source until the webcam is running in Messenger - try setting it up from scratch
1) The webcam is working outside of Messenger
2) Reboot webcam by unplugging the USB connection and inserting it again - its important if its been used elsewhere and prior to chat.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
Once you have your webcam working outside of Yahoo Messenger you have to configure it to messenger CONNECTION
Open messenger - on top toolbar > messenger > preferences > connection - select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the 2 lower boxes > apply > ok TESTING
> messenger > my webcam - warning panel will come on click 'ok' and your webcam will launch. DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK PERMISSION OPTIONS
>messenger > preferences > webcam - make your selections about who you will allow to view you
IN USE Your contacts may need to configure their connection the same as above or they may also get a "webcam not connected" message
Jun 16, 2008 | Logitech QuickCam Express Web Camera
I can't get my camera to work with my messenger program, can you help (AOL, Yahoo, MSN)? pls,help me to use my pc camera.i dont know how to open ok?
May 23, 2008 | Intel Easy PC Camera Webcam
Acer Crystal Eye Webcam and MSN Messenger
hi,the acer crystal eye has issues with mcafee site adviser either delete it as i did or configure it.search mcafeemessenger click on microsoft live messenger 2009 (v140) conference link to the appr opiate page hope this is helpful.
Mar 19, 2008 | Acer Aspire 4315 Notebook
Can't transmit video via MSN Messenger
As long as she is accepting your call when invited it should show up a little MSN advert then show your picture. The problem may be at your end, so check that you have the cam set up in settings and you both allow video to be accepted, ckeck all the web cam settings and menu options. If you haven't already, download MSN live messenger.
Mar 07, 2007 | Labtec Webcam Pro
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
735 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
