Question about Samsung SGH-d407 Cellular Phone
Turning the key sounds off Samsung A412
I want to turn the constant sounds you hear everytime you press a button on the phone. This is getting frustrating, most phone have keypad tones 'tunr off' feature under phone settings. Why is it so difficult on this phone???
  • 61 Answers
Customize profile Silent : select ring tone which ever you want and select Volume and activate the profile
then check keypad sounds or coming or not.
Regards,
Suraj
Posted on Feb 19, 2009
Unlock code for my sgha412
You can get the Unlock code for SAMSUNG SGH A412(A412) model phone at
Superunlockcodes.com/samsung-a412/rs12wp9/ and Unlock it from network lock...
Sep 01, 2012 | AT&T Lands Phones
My phone wont turn on what is the problem ?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 07, 2012 | Samsung Dart T499
Samsung SGH-A412 Mobile Phone Unable to get a ringtone on incoming SMS
to increase the sound on your message alerts please goto Menu, Settings, Phone Profiles and then highlight the profile you are currently using. Then press Options and then Edit. In this menu scroll to your right once to access your message alerts. From here please make sure the volume of the alert is set to 7
Jan 21, 2010 | Samsung Cell Phones
Can't turn the texting key sounds off!!
Okay go into your menu and go to your Fourth option which is a little silver wheel which has the options call date&time all that.Go to sound which is your third option. It will have an option that says volume. Go into that and it will say keypad you can shut the noise off that way hope it helped if you need more clarification let me know.
Aug 22, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
My samsung blue flip cell phone, everytime I press 369 or#....
If you notice the 3,6,9, and # are all on the same column. There is probably some corrosion under the keypad from a spill or moisture. If cleaning the membrane switches won't work try replacing the keypad (the electronic portion, not the rubber). Repost if you need instructions. I can put some parts up on ebay for you too.
Aug 17, 2009 | Samsung Cell Phones
How do you silence a samung sgh a412 phone?
keep on pressing the # key to get it into silence mode.
Jul 14, 2009 | Samsung SGH-t629 Cellular Phone
How do I turn my Samsung Juke All sounds off mode back on
Press the Volume Down button on the side of the phone. That'll do it!
Dec 24, 2008 | Samsung SCH-U470 Juke Cellular Phone
Phone getting switched off when speaker is turned on
(Just received this from Panasonic Support...Thanks Panasonic!) The following might be worth a try.... Resetting Handsets & Base Unit: 1) Unplug AC adaptor from base unit for 30 seconds. 2) Reset handsets by removing/reinstalling all batteries.
Re-register each handset to the base unit by following the steps below:
1. Press MENU, #, 1, 3, 0 on the handset. 2. On the base unit, press and hold the LOCATOR button for 4 seconds until the registration tone sounds. 3. On the handset, press the soft key below OK and then wait until a long beep sounds. 4. Press the OFF button to exit. Situate the base unit in a different location. Change the line mode from A to B or vice-versa by following the steps below:
1. Press MENU on the handset. 2. Press #, 1, 2, 2. 3. Press the up or down arrow key to select the desired setting. 4. Press the soft key below SAVE. 5. Press the OFF button to exit. If the problems persist, your unit is malfunctioning and is in need of repair or replacement.
Dec 21, 2008 | Panasonic KX-TG4321B Cordless Phone
Reset
I had the same problem turn the sim card around with the cut corner facing out
Aug 31, 2008 | Samsung SGH-d407 Cellular Phone
Samsung a737 is the model
Here is a quick run down on that and a link to the PDF manual that will tell you everything you need to know.
This is for a Verizon Samsung u700 mobile phone.
1.From the main screen, press OK MENU, use the right navigation key to highlight SETTINGS & TOOLS and press OK.
2. PRESS (BUTTON 4ghi) SOUNDS SETTINGS.
3.Press (button 1@) CALL SOUNDS. or Press (butoon 1@) CALL RINGTONE to get new ringtones from "GET IT NOW" (GET NEW APPLICATIONS) or choose from the pre loaded ringtones.
4.Press (button 2abc) CALL VIBRATE to turn Call Vibrate On or Off.
5. Press OK to save settings
Aug 10, 2008 | Samsung SGH-E630 Cellular Phone
Samsung SGH-d407 Cellular Phone Logo
417 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
