Question about Geberit Plumbing
Infrared faucet SPORADIC OPERATION
The faucet runs too much and sometimes not enough. I clean the external lens sometimes this helps but not always??
Tom
    President:
  • 2,976 Answers
Simply a drop of water can be a problem. I deal with 24 of these things on a daily basis. They're nice but, I would recommend replacing them with manual faucets.
Posted on Jul 02, 2009
Faucet works sporadically even thought solenoid is disconnected
You are saying that the water comes on by itself? What water pressure do you have?
Apr 08, 2016 | Delta Pilar Pull-Down Single Handle...
Toyota avalon 2000 engine stops even after the engine is warm. sometimes the idle is erratic.
Maybe the Throttle Pedal Actuator needs a clean. If dirty the flap is not opening as it should.
Mar 11, 2014 | Toyota Avalon Cars & Trucks
Have fitted new fluidmaster flush valve, has a dual flush button operation but water constantly dripping down bowl so fill valve activates sporadically to maintain water level. how can i stop water...
Flapper not seating properly,either get new flapper or try a old trick i've used shut off water to tank and drain tank then add hot water to tank and let set for a while sometimes that will soften and seat flapper it's worth a try it's free.
Jun 08, 2011 | Fluidmaster & Fits-All Faucet Connector
Faucett keeps running
check the ground wire if it is lose the faucet will do this.
Feb 01, 2011 | Ultra Max Symmons ULTRA-SENSE SENSOR...
Spin cycle does not always remove enough water, so...
Take the agatator out and check the drainage it will be bloked clean as required. Hope this helps
May 17, 2010 | Washing Machines
Acomdata external HD not read. Clicking sound.
Try taking it out of the casing and putting it into another external hard drive case. That is if you can, if its making a clicking noise it probably means your hard drive went bad or it means its not getting enough power to run make sure all the cords are hooked up tight. I had that problem once the hard drive wasn't getting enough power and i had to mess with it on the inside to make it have enough power. I'm not saying take the hard drive apart im saying take the casing off it and check the inside cords to see if they are tight enough. If that doesn't work leave a message and ill try to help again.
Jan 04, 2010 | Acomdata HybridDrive E5 Hard Drive
Infrared on tv not working or sporadically with any remote that is working with all other equipment (i.e. dvd...). Where is sensor, how to clean
to see the infrared i would recommend you to read the article at http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
this way you can ensure if the infrared is emited normally from your remote control, afterwhat you can decide what to do.
Nov 15, 2009 | Sylvania SRT2232S 32" TV
Oster Golden A5 Clippers will not cut
These kinds of clippers are fussy about oiling and dirt. It is essential that the blades be spotless and well oiled FREQUENTLY. Oil after every haircut always. Also, if there is not enough tension on the blades, the hair will slip between the blade and blade guard, getting caught and damaging the blades. Blades should be screwed on tight. Also, it may be time to replace the blade if nothing else helps. These blades do not last very long in my experience especially if not carefully cleaned and oiled.
Feb 28, 2009 | Oster Golden A5 1-Speed Universal Motor...
Noisy wii console
Hi Sky606, have you tried cleaning the game disk? Have you tried using other game disks in the wii to make sure it's not just one disk that is causing the problem. Do you have a Nintendo Wii CD / DVD Discs and Lens Auto Cleaning System ? If you don't you might want to purchase one and see if that helps, because your wii lens might need cleaning ! If all of that fails,your wii may need repairs, the lens that reads the CD/DVD could need adjustment or replacement ! One other small note,I always have a small external fan blowing on my wii when in use so that the wii wont over heat. Heat kills electronics ! I Hope this advice helps.
Jun 06, 2008 | Nintendo Wii Console
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Plumbing Logo
122 people viewed this question
Top Geberit Plumbing Experts
Donni Steen
Tom Chichester
Are you a Geberit Plumbing Expert? Answer questions, earn points and help others
