Question about Motorola Mobility RAZR V3
VOICE DIALING need to know how to set up the voice dialing so when i say a name it dials . i also use the blue tooth so that makes it easier.
  • 61 Answers
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Posted on Feb 19, 2009
I would like to know how to enable voice-dialing on my Samsung Intensity, I cant seem to figure it out....thanks
Voice dialing is enabled by default on the Intensity. All you have to do to use it (assuming you have at least one contact saved) is press the voice dialing button on the upper right side of the phone (near the camera) and on the menu that pops up, select Call (option #1). Then say the contact name you want to call -- for example, "Call Michael." You may have to confirm your selection, depending on your settings, and then the phone will dial the number you have saved for Michael.
Apr 17, 2010 | Samsung SCH-U450 Cell Phone
Can't Set up Voice Dialing
Are you saying "name dial" first? Name dial works only with the contacts in the PHONE contact list/ address book, otherwise you have to say "digit dial" and repeat the number.Also make sure you have gone to settings>personalize>voice dial set up, first.
Aug 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Voice dialing on the i870 motorola phone
Using a Voice Name
Follow the prompts of your voice dialing service, first which means that you need to run the set up of this feature. Each number can be assigned a voice dialing option, which the phone must be trained to recognize.
If you have created a voice name in Contacts for the number you want to call, say the voice name into your handset to enter the number.You can use a voice name to enter a handset number
with the flip open or closed.
1. Press and hold t until a prompt appears telling
you to say the voice name.
2. Speaking into the microphone, say the voice name assigned to the number you want to call.
Your handset plays the name back to you.
If you are making a Private call, press and hold the
PTT button to place the call.
If you are making a phone call, the call is placed
automatically.
(Tip: To stop a phone call from being completed,
press . if the flip is closed or press e.)
Mar 17, 2009 | Motorola Mobility i870 Cellular Phone
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Will not voice activate
Does your Treo 700W support "voice dialing"? I searched the whole user guide for the Treo 700W and it does not say anything about dialing by voice. If the phone does not support it than no matter what Blue Tooth unit you use you will not be able to voice dial.
Jun 02, 2008 | Motorola Mobility H700 Wireless Headset
VOICE DIALING
Dear chuckbonus
Please find below the complete manual for your phone. The phone is indeed voice tag capable. You will find the information requested at page 43 of the user's manual.
http://www.cellphones.ca/upload/manuals/motorola-i880-manual.pdf
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 12, 2008 | Motorola Mobility i880 Cellular Phone
RAZOR V3 VOICE DIALING
If you have the v3xx, it has speech recognition built in, you just press the voice dial key on the right side of the phone and say "name dial", then say the name of the address book entry you want to dial. The speech recognition matches up with your address book entries and repeats the name back to you. If you have multiple entries, it asks "which one". It's very cool and mine works very well. I was going through the same frustration you mention, looking for a way to add a "voice tag" to an address book entry like my old phone, but this is way cooler! Hope this is the fix for yours as well, good luck!
Dec 14, 2007 | Cell Phones
Motorola Mobility RAZR V3 Logo
292 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
