Question about SanDisk Sansa e200 MP3 Player
Sansa e200 - blue/black display and doesn't play songs
My sansa e200 MP3 player shows up a blue/black display on power up. It gets kinda locked there.
I can't see the menus and neither does it play songs.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Mar 26, 2009
The screen of my Sansa Clip 2GB showed illegible signs two days ago when I last played it, but I could get songs playing. Through my computer I then cleared all playlists, deleted the songs etc. Then put...
Restoring your player can be done in 2 main steps:
>>1. For updating the firmware, the player should be switched to MSC mode.
This could be done through the menu. When not knowing what the display shows, use the forcing method in next link:
http://kb.sandisk.com/app/answers/detail/a_id/61/sno/0
See the Sansa Clip steps below:
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
>> 2. Once connected in MSC mode you can use the firmware updater when having Windows operating system, see next page:
http://kb.sandisk.com/app/answers/detail/a_id/300/kw/firmware%20updater/r_id/101834
For others who have MAC or Linux operating system you can not use the firmware updater: firmware should be manually downloaded from Sansa Forums and installed afterwards:
http://forums.sandisk.com/sansa/
If this was helpful I'd appreciate your answer.
When needing more help, just add a comment in this thread.
Mar 03, 2010 | SanDisk Sansa Clip MP3 Player
How to recharge the Sansa e200
Play songs then on one of the tabs it says Sync then click the arrow under it (you have to move your mouse around the tab to find it) then click Sync Now Playing, and wait for it to finish.
Jun 21, 2009 | SanDisk Sansa e200 MP3 Player
Sandisk Sanza e200 seires display is blue
Try a reset = Press and hold for 20 seconds the ON and PLAY (>||) buttons at the same time.
Jan 26, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e200 6MB does not start correctly
1-866-726-3475 Sandisk Customer Support
www.sandisk.com
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
Mar 26, 2008 | SanDisk Sansa e200 MP3 Player
Transfering songs
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
My sansa e200
"unknown" songs taking up memory in my sansa e200
Renew music svc sub, convert to Mp3, or update/remove DRM licensing
Nov 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
