Question about Intel D101GGCL Motherboard
2 RAMs are not getting detected together -- Intel D101GGC
I am using intel D101GGC mother board. I was using 256MB RAM. Recently I fitted an another 1GB RAM. But it is not getting detected. I tried again by removing the 256MB, then it is getting detected. I also tried with both 1GB and 128MB ram. Every time only the one with smaller memory get detected. My problem is when I insert 2 RAMs together only one is getting detected, with smaller memory. Both slots are working properly. May I know what is the problem. Is there any settings with the motherboard??
  • 121 Answers
INSTALL BOTH RAMS THEN GO TO THE BIOS MENU IF THEY ARE NOT THERE TRY TO SET THE BIOS SETTINGS TO FAIL SAFE DEFAULTS ALSO TRY TO SWAP THE RAMS WITH THE SLOTS SEE THE FREQUENCY OF BOTH THE MEMORY MODULES IF IT DIFFERS TRY TO REPLACE THE NEWER ONE WITH THE SAME FREQUENCY SAME AS TO THE OLDER RAM
Posted on Jul 08, 2009
  • 530 Answers
Hi im josh in cebu phils. friend no setting to be modified the problem is in *********** board.it can not detect two memory at a time especially having different value. coz when the memory works it will swap since one of the memory is hgher it will create complications.so to avoid such problem you choose to use the same value of memory in both memory banks. like if youre using 256 of the 1st memory bank use alson 256 for 2nd memory bank. then try to use the same brand for better. good luck!
Posted on Feb 19, 2009
RAM Problem in intel D915GLVG mainboard
Most likely the pc400 hynix is incompatible with the mother board, or with the memory you are leaving in place. Try using just the pc400 sticks, if you still get system beeps then you are using incompatible memory. You should go to centon, or other memory manufactures wesbsite and look up what is compatible with the mother board and get that memory for the system. My bet is going to be pc3200 memory.
Hope this helps
Jan 25, 2012 | Intel D915GLVG Motherboard
I have intel 101 Ggc Mother board and intel pentium D processor , i was using 756MB ram (512+ 256MB) RAM. But after i brought 1 GB ram and Used it instead of 256 MB Ram the system started restarting...
There is a chance that you have faulty RAM module. If computer is stable on POST (until Windows boot-up) I would suggest to use some testing tools to test that RAM with your motherboard. There is a good program called MemTest. You can find it online if you search Hirens Boot CD. Download it, burn image to disk, put 1GB RAM into motherboard, start-up PC and boot from CD. Then you'll search for Memtest program. I would suggest to leave PC for at least 6 hours for testing to find out if it's faulty or not (better to leave for 24 hours).
Aug 17, 2011 | Intel D101GGC Motherboard
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
Vista compatiable
intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
Nov 26, 2008 | Intel D101GGC Motherboard
Memory Upgrade
ask for ddr1 ram of 1 gb.also take your old ram which is at present in your pc to match the locks with the new ram.
it will cost u near to 50$.
thanks.
Sep 18, 2008 | Intel D101GGC Motherboard
D101ggc
Unplug all cards and in case uninstalled the grafik card.
Then check your memory modules.
If one module is defective or it has contact problems you will get no display and a beep.
I think it's a good idea to uninstall and reinstall the RAMs.
If the beeper sounds further, change the RAMs.
Jul 18, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard PCI Express compatibility issues........
i'm using NVIDIA GEFORCE 8600 GT on my d101ggc board and its working fine
Jun 30, 2008 | Intel D101GGC Motherboard
Regarding Upgradation of Rams in My mother board
Please don't post your question twice, I've already answered your other post of this problem
May 21, 2008 | Intel D845GVSR Motherboard
Intel D101GGCL Motherboard Logo
123 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
