Question about Ulead Videostudio 8 for PC
How record only audio with easycap usb 2.0
I'm use adobe audition, audacity, cool edit but with any i can't record with my easycap thanks
  • Anonymous Feb 20, 2009
    VSH to DVD ,easycap no input signal or signal unclear.Did every thing no results.
  • mdl1348 Feb 21, 2009
    I have the same problem
3 Suggested Answers
  • 3 Answers
SOURCE: Audio out of sync
You may want to put the audio into the microphone-in of your laptop and make menu selections for audio via that line-in port when recording. I found as well that the audio sync was out of whack when trying to have it go with the video through the EasyCap..
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Audio in EasyCap/VS10
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly.
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound. Although I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Hope this helps!
Posted on Jun 05, 2008
hi
i upgraded the driver to stk1160 and the device is working correctly. i still cannot get the sound in the pc loudspeakers coz there is no usb-audio device installed for playback, just for recording. but that is a minor glitch. the sound is recorded with the video capture.
i have not tested the audio capture yet but i assume it will work just the same.
btw, i uninstalled ulead videostudio and just use windows moviemaker, the quality is fine.
download the driver from http://rapidshare.com/files/130191719/syntekSTK1160.rar.html
Posted on Nov 12, 2008
What is the real purpose of the adobe audition?
Adobe Audition (formerly Cool Edit Pro) is a digital audio workstation from Adobe Systems featuring both a multitrack, non-destructive mix/edit environment and a destructive-approach waveform editing view.
Adobe® Audition® software delivers the professional tools you need to make your video and audio productions sound their best. Handle a wide range of audio production tasks efficiently, including recording, mixing, and sound restoration.
What's new in Adobe Audition
au-native-mac-support-147x83.jpg Native Mac OS support Record, mix, edit, and master your audio with a powerful cross-platform audio toolset: Adobe Audition CS5.5 runs natively on Mac OS X v10.5 and v10.6 as well as Windows®.
au-roundtrip-editing-premiere-147x83.jpg Roundtrip editing with Adobe Premiere Pro Easily sweeten audio for video. Pass individual clips and multitrack mixes from Adobe Premiere® Pro CS5.5 software to Adobe Audition for editing, or send Adobe Premiere Pro sequences with a reference video to Adobe Audition for complete soundtrack creation.
au-project-exchange-147x83.jpg Project exchange with third-party NLEs and DAWs Easily move sessions between Adobe Audition and Avid Pro Tools using built-in OMF import and export functions in Adobe Audition. Share files with other video NLEs via XML interchange.
au-5.1-support-147x83.jpg Native 5.1 multichannel support Edit multichannel files and mix your projects in 5.1 surround. Adobe Audition CS5.5 includes a Surround Panner in the Mixer View, as well as a new Surround Reverb effect and Amplify, a multichannel gain processor.
Aug 17, 2011 | Adobe Computers & Internet
Audiobooks sound like they are being read in fast forward mode. Song are good, just the audiobooks? Can I edit the audiobooks somehow?
Yes you can. Here are the steps on how to edit an Audiobook:
1. Find an audio-editing software which has the editing features you want, and download it. Audacity and Adobe Audition are two popular choices (see links in Resources).
2. Transfer the unedited reading of your audio book to your computer's hard drive (if necessary).
3. Open your audiobook file from inside your audio-editing software. Many audio-editing software programs come with automatic file conversion capability so that when an audio file is opened, it's automatically converted to a medium that the program can work with. If your software doesn't have this capability, you'll also need to download audio converting software. Choose software capable of converting the file type of your original recording to a file type supported by your editing software.
4. Play back and listen to the reading of your audiobook. Stop the playback in areas you'll need to edit, such as a word or phrase you stumbled upon, long pauses that should be shorter, extraneous talking, bodily noises or the sound of paper rustling. You can insert rereads of certain passages, silence or reduce the volume of loud breathing and background noise.
5. Save the reading of each chapter of the book as an independent file. Saving the entire book as one file will make indexing the book much more difficult. If the editing software you're using has a multiple track feature, you can copy and paste each reading of a chapter to its own track and save each track as its own file. If your editing software does not come with a multiple track feature, you'll have to keep a master copy of your audio reading then create a copy of this master. Open the copy of your audiobook and delete the reading of all but one chapter of the book, then save that one chapter. Keep repeating this pattern until all of your chapters have their own independent file.
6. Listen to the edited reading of each audiobook chapter all the way through to make sure that you've performed all the needed adjustments.
Resources:
NPR: The Art of Recording an Audio Book (video)
Free Download of Audacity Sound Recording and Editing Software
Download Free Trial of Adobe Audition Audio Editing Software
Hope this information helps!
Apr 09, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
How to record music on ThinkPad!! Thanks
1) Turn on your mic 2) Start windows sound recorder 3) Start recording 4) Jam out on your instrument(s) 5) Stop recording 6) ... 7) Profit
In truth, this is a terrible device to record music on. You should look into getting a mixer (with as many tracks as you need) and a dedicated computer with a high quality sound card (M-Audio) is a good brand.
If you're thinking about making electronic music, look into FL Studio. http://flstudio.image-line.com/
More details would allow me to answer with more precision.
Mar 01, 2011 | Lenovo Computers & Internet
I have a sony mz r500 minidisk. can i upload songs to computer, after I use it to record to minidisk?
I don't think this is designated a "Net-MD" - is it? If so, by using the proprietary software (Sonic Stage), recordings can be transferred from the computer via USB to the MD unit - and back again.
You won't be able to "transfer" using a USB cable if the recordings didn't originate via Sonic stage. But you can record them in real time using Cool Edit, Adobe Audition or Audacity (free proggie!). This is the only way of transferring music from any non-USB equipped MD unit, or any MD unit that made the recordings with a mic or using line-in.
Apr 20, 2009 | Sony Walkman MZ-R500 PC Personal MiniDisc...
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Echo problem in adobe audition 1.5 (not environmental)
My best guess to start with is a reverb setting of some sort.
Are you recording in multitrack or edit view?  If one, try the other, and see if you get the same results.
Another guess would be a sound-card setting.  If you have any special effects setup on your soundcard (onboard, pci, pci-express, usb, etc), that could cause it.  Things such as 3d-surround settings, environmental settings, etc..
Also, what version of Windows?  What sound card/ audio interface?
Jan 05, 2009 | Adobe Audition 1.5
I cant record nor play while in Multitrack View, i can only play while in edit view ...? This is for adobe audition 1.5 ? Anyone know whats going on ???
Need more detail: 1. What sound card are you using?  - You need to make sure the correct hardware is selected as your record and playback types.  For instance, if you have more than one sound card, you could have easily the default one setup, but you really need your recording one - such as an ASIO driver - such as for external USB mixers.
2. What version of Windows?
My best guess is the hardware setup is off.  You have to have the correct hardware setup for Audition to see it.  Wave view and Multitrack view have diferent settings, each, so you have to set them up separately.
Dec 30, 2008 | Adobe Audition 1.5
Direct sound is not supported....
Follow these steps (Windows Vista):
Control Panel - Hardware and Sound - Sound - Manage Audio Devices - Record - Right click to show all the devices (including the deactivated ones) - Activate all the devices you can.
In Adobe Audition:
Edit - Audio Hardware Setup - Edit View - Control Panel button - Direct Sound Input Ports - Enable one device (default input will now show the device). Now you will be able to record sound.
Jul 24, 2008 | Adobe Audition 3 for PC (22011292)
Ulead Videostudio 8 for PC Logo
1,107 people viewed this question
Top Ulead Computers & Internet Experts
Barbat Nae
Barbat Nae
Daniel Florin
Daniel Florin
 Grubhead
Grubhead
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
