"Lost" modem access code
I am trying to access my SpeedStream 5100 modem, but an error message says the Modem Access Code is incorrect.  I've had the modem for nearly four years and the code (yellow sticker on the bottom) has always worked.  What now? I have a Siemens SpeedStream Model 4100 and the sticker which had the modem access code is ripped off. My DSL people,(ATT/Yahoo) tell me I need to get it from Siemens. I tried to find it but having problems even finding their modem equiptment website. Frustrating.
  • Anonymous Apr 19, 2009
    Same here
  • 32 Answers
This site may work for You:
http://www.softwaredriverdownload.com/download_siemens_speedstream_41004200_dsl_modem_manual.html
looks like a manual install of the driver packet. but it's FREE! Good Luck
Posted on Feb 20, 2009
I have the speedstream 5100 modem. I just replaced my xp machine with a windows 8 and I can't get to the internet now. It tells me ethernet doesn't have a valid IP configuration. Any sugges
If you do not have a router you have to reboot the modem first, Modems pair with one device at a time using its MAC address, using a router allows you to add remove computers to your internet access without rebooting the router for every device because the modem pairs to the router and the router shares its internet with your other devices.
Jan 28, 2013 | Efficient Networks SpeedStream 5100 Modem
Have an old speedstream 5100 adsl modem from SBC. Would like to use it with new AT&T service. Problem is I have no Installation CD. Havnt used modem in many many years, tho I'm 99% sure it still...
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. At the login screen type in your SBC/AT&T member ID and password.
4. Click Connect.
5. If everything is successful you will get a screen that says, "You Are Connected." and your Internet light will go solid green. If you username or password is invalid you will get a screen stating such. If there are other problems you will get a screen stating, "The DSL connection is down."
Sep 16, 2010 | Efficient Networks SpeedStream 5100 Modem
Am trying to find out if can use a router with speedstream 5100 Part # 060-E142-A02(modem access code 2038304758?
Yes you can. Connect the ethernet cable (circled in the image below) from your speedstream modem to the Lan port on your router. Hope this helps. 1c801d4.gif
Jun 24, 2010 | Efficient Networks SpeedStream 5100 Modem
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
Computer tells me i have no internet connection but im online
this sounds like the internet service is available because the internet light does come on but it sounds like the password is incorrect. i suggest you contact your ISP to confirm you access is ok
Jul 01, 2009 | Efficient Networks SpeedStream 5100 Modem
Cant access speedstream modem
Turns out that the modem stopped transmitting a wireless connection so that is why we couldnt get it working. After nearly putting a hammer through the laptops, we decided that we had better buy another modem. It now works better than ever :-) (phew)
Mar 25, 2009 | Efficient Networks SpeedStream 5100 Modem
Cannont Access Modem
1. click START-settings-Controll Panel- Network Connections
2. right click on your LOCAL AREA CONNECTION and select PROPERTIES from the menu.
3.when properties opens, select TCP/IP by highliting it, then click on the properties .
4.once the new window opens titled "internet protocol (tcp/ip) Properties you will need to check the boxs that say "Obtain an IP adress automatically" and "Obtain DNS server automatically"
5. Click on OK
6.reboot
Hope this helps, post if you need further assistance.
Oct 05, 2008 | Efficient Networks SpeedStream 5100 Modem
Router to connect or sub the speedstream 5100
Option 1 (easy)
you could buy a switch or router and put in line with your modem.
you will have to set up appropriate networking on the xbox
DSL --> MODEM --> SWITCH <-- PC
^---- XBOX
Option 2 (harder)
you could get a wired/wireless AP (Access Point) for your PC and run ICS (Internet Connection Sharing) through Windows. connect the XBOX through your PC
Aug 21, 2008 | Efficient Networks SpeedStream 5100 Modem
go to dslreports.com, under forums see if there is a specific help for your telco or modem type. They are very helpful
Jun 01, 2008 | Efficient Networks SpeedStream 5100 Modem
Computers & Internet Logo
1,684 people viewed this question
David Payne
David Payne
