Question about Apple iPod classic MP3 Player
Can't turn on ipod
How do i turn on the ipod. i don't know what button to press
    President:
  • Apple Master
  • 688 Answers
Press and hold the center button
and to turn it off, press and hold the play/pause button.
Posted on Mar 05, 2009
How do I turn off iPod?
Press and hold the top of the outer button.
To force a reboot if it freezes, that and the centre button for 10 seconds until the logo appears.
Jan 31, 2016 | Audio Players & Recorders
Trying to swicth off my i pod
Slide the Hold button on the top of the iPod so no red mark is visible. Press the main menu button until you see a long list of options (Artists Albums Songs Extras......) use the scroll wheel to find the sleep press and hold the center button in or Locate the Play/Pause button on the iPod. The Play/Pause button is at the bottom of the wheel around the select button. Press and hold the Play/Pause button until the unit powers off, about three to five seconds. Press any button on the iPod to turn the power on.
Feb 03, 2013 | Apple iPod MA446LL/A MP3 Player
I don't know what happened but ipod does nothing. tried resetting (menu & select)(menu/select & select/play) not sure what else to do. plugged into computer and still nothing. please help
Welcome to Fixya
Try resetting the ipod by pressing the middle button and the menu button at the same time for 5 to 10 seconds. The ipod logo should appear after the reset has done.
Thank you for using FIxya!
Oct 02, 2011 | Apple iPod classic MP3 Player
How do you turn down the volume on the Hott MP3 player?
hold volume button down util the icon turns red then adjust volume with right arrow for up and left for down. when icon goes back to black it should have adjusted to the volume. Also the volume is listed numericly the higher the number the louder it gets.
Jan 12, 2011 | Audio Players & Recorders
Alpine cde-9870 non-ipod mp3 player AUX FUNCTION
When you press the SOURCE/( ' ) button and select iPod as the source, make sure you turn on AUX+ so that the external device is used as the source. AUX+ is turned off when you want to use an iPod with this head unit.
I don't know why some people thought to answer your question with an answer based on a different model.
May 06, 2010 | Alpine Car Audio & Video
Apple Ipod 30 GB
to turn the iPod off, press menu back to the first page and press and hold the play/pause button.
the lower most button on the clickwheel
May 12, 2009 | Apple iPod MA446LL/A MP3 Player
Does not turn om
it's possible that you have a bad power switch circuit .
have you plugged an a/c charger into the ipod yet?
it should boot with an a/c charger.
also,
plug it into the computer and see if itune recognizes it, if so then your LCD is probably bad and you just don;t know it's on.
and if you have put the ipod into dfu mode it will come up on itunes as being in recovery mode.
go ahead and restore it, if you worried about a jailbreak, dont, you can jail break it easy after it's restored. but i would make sure you have a copy of your current firmware prior so you can restore to the some firmware or something close.
here is a link to a firmware for the 2g: ipod touch firmware
here are the steps to put the ipod in dfu mode:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
When you go to press restore press the SHIFT key when you hit restore and choose the firmware you have downloaded.
Mar 11, 2009 | Apple iPod touch
Turning off IPOD 1059
If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Feb 22, 2009 | Apple iPod MP3 Player
My ipod nano wont do anything
Press and hold the center button while pressing down on the menu buttton. The Apple logo will appear. This will reboot your Ipod.
If that doesn't work, restore your Ipod to factory settings by plugging your Ipod into Itunes and select restore to factory settings from you Ipod settings in Itunes.
Aug 25, 2008 | Apple iPod nano
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod classic MP3 Player Logo
42 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
