Question about HP Scanjet 7800 Pass-Through Scanner
At scaning time show
HP SCANJET 7800 at scaning time show "There are no paper in document feeder?
  • 43 Answers
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Posted on Feb 22, 2010
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
The belt inside my scanjet 4200c has come off. How do I reattach it? I have opened the scanner. It looks to be relatively easy but I don't know how to attach the belt to the motor etc
Instructions
1 Lift the hatch on the feed tray and pull up the large green tab to the left of the roller. Remove any jammed or torn paper from under the roller and around the feed tray.
2 Pull the input feed tray out of the automatic document feeder. Grasp the feed tray with both hands and pull it straight out.
3 Check the interior of the automatic document feeder for jammed paper. Remove any jammed paper, then reinsert the feed tray into the automatic document feeder. Push down the feeder cover until you hear a click.
Mar 08, 2011 | HP Scanjet 4200c Flatbed Scanner
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
Hp scanjet 7800 shows document feed empty
Hi
these scanner take a bit of work-open the front and then close the front- there is a latch to open the front of the scanner at the top of the front panel. this will clear the 04-08 or 24 error.
sometimes it's best to switch the scanner off and then back on which will reset the connection between the scanner and the PC
regards Liz
Dec 12, 2008 | HP Scanjet 7800 Pass-Through Scanner
Hp scanjet 7650 document feeder is not working
did u buy cheaper paper that will do it tease the sensor in it sumties try to dl latest driver form hp.com ok remove old 1st
Oct 09, 2008 | HP ScanJet 7650 Flatbed Scanner
Feeder
Hi
the scanner will do that sometimes, it's easiest to just feed the pieces through one by one when that happens.
Regards Liz
Jul 03, 2008 | HP Scanjet 7800 Pass-Through Scanner
HP ScanJet 5590 automatic feeder not working
Have you tried scanning in the flat bed mode? Does it scan okay? If the image is good, then there is no problem with scan module. Check your page settings. If the page size selected for scanning is smaller than actual size, there can be some peoblems. Try and scan with max size. Check if the sensors are dust/paper free. A small piece of paper (The small round discarded piece from Computer stationery) in the paper sensor can create trouble.
S. Mohan
Feb 21, 2008 | HP Scanjet 5590 Flatbed Scanner
Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Dec 07, 2007 | HP Scanjet 8250 Flatbed Scanner
ADF document feed
Hi, The problem seems to be a piece of debris , paper stuck in the ADF roller assy. You can check this by opening up the adf cover and inspecting the paper path. I have seen where a very small peice can cause paper path problems to where something is blocking the paper> Good Luck!
Dec 03, 2007 | HP 5590 ScanJet Flatbed Scanner
HP Scanjet 7800 Pass-Through Scanner Logo
170 people viewed this question
Ben Johnson
