Question about HP Photosmart A826 home photo center Printer
Paper won't feed in my HP A826
I get a message that it is out of paper, which it isn't. The rollers won't grab the paper. I've tried everything on the HP troubleshooting site. Except cleaning the rollers, as there is no way to open the back of the printer. Sometimes if I open the back and push the paper down manually it catches and prints
Joed911
  • 4338 Answers
SOURCE: Paper Feed
Here is an in depth document on Paper and carriage jams on your HP printer. there is a paragraph on how to clean the rollers, which may fix your problem.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&lang=&rule=35051&product=306892&docname=buu03110
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 08, 2008
Ajkill
  • 2035 Answers
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
mahjid
  • 202 Answers
SOURCE: paper isn't catching on the roller - terrible sounds
make sure the paper is not wet and not damp. possible buy a new paper
Posted on Jul 14, 2009
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
celibytes
  • 70 Answers
SOURCE: HP PSC 1350 printer won't feed paper
Check the gear on the left side of your printer where the disk encoder strip is attach,the gear is not holding the metal shaft your need to replace that gear. The problem is in the inner hole where the shafting is attached.
Posted on Nov 03, 2009
Align PIckup Roller Gears HP Officejet 4500
Reset the product:
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 6 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
If it does not resolve then service the product
Jun 21, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
Paper jam error code 13.01.00 hp 3505n printer
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding. A lot of times, it is as simple as the paper backstop has slid back and the roller can't grab the paper that is 2 inches out of reach. Since you've replaced the tray and paper, I would think you might have noticed that. Is the paper moving out of the tray at all?
Jul 04, 2012 | HP COLOR LASERJET CP 3505 N PRINTER
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
Printer feed will just not grab paper
Rollers need replacing. They are supposed to have tread like tires, if not, Replace.
Apr 06, 2010 | Canon Office Equipment & Supplies
HP C4280 won't grab paper,tries then says out of paper
You need to clean the feed rollers. Open your HP Notification tray and check up some options. It's really intuitive so if you fiddle around a bit, you'll probably find an option to clean the feed rollers.
If not, dampen a cotton cloth and wrap it on a ruler and scrub the feed rollers yourself. Just look into the tray where you put papers and on the back you can find normally one feed roller on the right side. It's not that difficult.
Good luck.,
Feb 19, 2010 | HP Photosmart C4280 All-in-One InkJet...
My printer does pick up any paper
This video will help with that problem.
May 07, 2009 | HP Officejet J4680 InkJet Printer
HP LaserJet wont pick up paper
Try cleaning the feed roller. It may have debris on it, making it slip. Use alcohol on a lint free cloth. Often you'll see on the paper where the roller slipped on the paper. There may be a dark smudge where the roller slipped. Check it out.
Dec 29, 2008 | HP LaserJet 1200 Printer
Hp 3310 paper feed
Take off the back of the printer - there is a door running almost the full length which has a latch. Using regular rubbing alcohol and a Q-TIP(R) cotton swab, clean the little rubber rollers which grab the paper from the tray. The rollers you need to clean will be low and on the left as you look at the back of the printer and they are about 2 inches inside the printer. There are 2 of them. Paper dust builds up on them and they fail to grab the next sheet of paper, causing the error message. Works every time!
Sep 14, 2008 | HP Photosmart 3310 Printer
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
HP Photosmart A826 home photo center Printer Logo
179 people viewed this question
Ben Johnson
