Question about Ricoh Aficio 3025 All-In-One Laser Printer
Lanier LD225 Drum Reset
I've rebuilt the photoconductor unit but need to clear the "replace photoconductor" message. Will appreciate any assistance.
There is a small "flag gear" on the back that needs to be in the "up" position to contact the button on machine and initiate it when it is installed
Posted on Feb 19, 2009
My lexmark e120 in the setting page indicate replace photoconductor and this is new.
The replacephotoconductor message should be cleared only when the photoconductor kit has been replaced. If PC kit is new and still getting samemessage, please reset the photoconductor counter to zero. For further assistance,please contact Lexmark Technical Support
May 03, 2011 | Lexmark E120 Laser Printer
Replaced drum but light continues to blink
To reset the photoconductor drum counter, press and hold the Cancel button on the printer until all lights flash in sequence. You can clear the Replace photoconductor message only when the imaging drum has been replaced. For more information on how to replace the drum, see the User's Guide.:
http://support.dell.com/support/edocs/systems/prn1720/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2010 | Dell 1720dn Laser Printer
My lanier is making dark copies
One of the most common reasons for a Lanier 5222 or 5227 to make dark copies is a problem with the drum unit or developer. Fortunately on those machines, the drum unit and developer are all self-contained in one easily-replacable unit, called the PCU (photoconductor).
If you don't have a new PCU handy, you can order one from the same company you get your toner from. The PCU should generally be replaced every 60,000 copies, but sometimes it may need to be replaced sooner (especially if you run a lot of dark copies or make a lot of copies of images) and it can often run longer than 60,000.
Replacing the PCU is easy -- it sits right next to the toner bottle, and all you have to do is slide the old PCU out and slide the new PCU in (once you remove all of the tape and other trappings from it). Instructions will be included in the box with the new PCU.
Please rate the effectiveness of this solution. Thank you!
Oct 10, 2010 | Lanier 5222/27 Laser Printer
We are receiving the error message "84 oc life exhausted". What can we do to solve?
84 PC Life Exhausted indicates that the photoconductor unit has reached its functional life. The photoconductor kit will need to be replaced. The printer will not function so long as the Exhausted message remains on the display. The only way to clear the message is to install a new photoconductor. After replacing the photoconductor unit, you need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark Optra SC 1275 Laser Printer
How to enter service mode on a lanier ld225
Press Clear/Modes, then 107, then press AND HOLD Clear/Stop
This will get you into the service mode screen.
Know what you are doing before going into any modes and changing anything.
Good Luck and Thank You for using Fixya
Jul 20, 2010 | Lanier Office Equipment & Supplies
Erase replace photoconductor message for lanier ld015
Its cheaper to replace it. If you reset the unit in a short period of time it will lock up with used toner. Once this happens you still will have to replace the PCU plus the added cotst of the damaged gears and extra labor.
Oct 14, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Our lanier machine (LD015f) keeps flashing replace
Open front and right door, remove toner, un plug photoconductor release photoconductor tab on upper left of it, new "PCU" will auto adjust, sold as a supply. Hope this helps. Carl
Jul 10, 2009 | Lanier UNKNOWN
How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
May 25, 2009 | Lanier Office Equipment & Supplies
Lanier LD225 copier with a error code 541
All clear huh, wow, what error code do you have sp7-403 1 thru 10 will show you the last 10, a code of 541 thru 548 relate to fuser with the fuser out there is no gap between the hot roll and pressure roll right? -Carl
Dec 25, 2008 | Ricoh Aficio 3025 All-In-One Laser Printer
ACULASER CX11NF Photoconductor reset - chip?
The reset chip will not provide you with a long term solution to your problem. The photoconductor unit is now full of waste toner and the photoconductive drum, prime charge roller and wiper blade are all worn, this is the cause of the message. Your only real and the correct solution is to replace the Photoconductor unit with a new one. Remember that this is part of the consumable set for this printer and is therefor costed in as part of the cost per page.
Should you proceed with the replacement chip, you will be opening yourself to deminishing quality print and eventual failure of the unit.
Gremlin11
Jul 24, 2008 | Epson ACULASER CX11NF All-In-One Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
663 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
