Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
I have a presario v5102us and it won't always boot up. I can her a clicking in the cd rom and black screen
  • kimmiegrif Feb 19, 2009
    thanks but the noise is definitely coming from the cd/dvd drive.
    The comuter will turn on and then it seems to be trying to boot from the cd rom.  At first you had to play around with trying to open the cd rom to get it boot...now that doesn't always work.  We turn it on and off continuously.  Then we close it up. Give up on it.  I then think okay...I will fix it...and turn it on and it boots up.  That happened tonight and now I am attempting a compaq pc recovery......I am at 70%
    Problem Solver:
  • 13 Answers
That clicking is more than liekly your hard drive and there is nothing you can do to prevent it from failing, back your data up and consider migrating to a new computer or ghosting your hard drive. BACK UP YOUR DATA. once it crashes that disk will be nearly inaccessible.
-good luck-
Will
compressionconnector.com
Posted on Feb 19, 2009
How to change setting in bios to boot from cd drive"?"
you usually dont have to change the boot order to boot from a cd. the bios should check the cd rom before booting from the hdd. However, if that isnt the case, you can always change the boot order.
go to the bios settings while u turn your laptop on. (It should be "esc" for HP. a message will be displayed at the bottom of the screen indicating the key. if not, try esc, f10, f11, f12. either one of them should work).
go to the boot order settings (May have a different name- boot settings/ boot priority settings/ advance boot options etc.).
Jul 13, 2014 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
When I turn on my laptop pc every couple days a black screen will come up and the laptop stops processing. Why? How to fix it?
I would suspect a glitch in the MBR/software, a black screen with a white cursor in the top left, BUT, Try this , when you shut down always unplug, remove battery when you use at home connected to AC. At boot in BIOS, BOOT sequence, change to Boot from HDD first. Also remove DVD's, CD's from the DVD/CD rom drive, if the machine has boot from DVD/CD rom as a default, it will try to read the disk in the drive first, delaying a switch to second HDD boot. This is a general idea in the Boot sequence procedure: http://helpdeskgeek.com/how-to/change-boot-order-xp-vista/
Dec 25, 2012 | Acer Computers & Internet
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
I have compaq presario 2100 i was using for 7 months now the screen is black can give me any solution
Try booting in safe mode by pressing the f8 button after the bios post choose safe mode and if you see the display just go to device manager through right click on the my computer and manage and display driver right click and uninstall and restart the comp and should be fine\
Thanks
Dec 05, 2010 | Compaq Presario 2100 Series: 1170B01-90...
Emachine T4060 -black screen-no cd-rom boot
If it is DVD Drive, then sometimes in BIOS you'll also find the option for DVD Drive together with CD Drive. Choose the correct one and boot your PC.
Please come back and vote for me, if this turns to be helpful for you. Thnx
Mar 27, 2010 | E-Machines T4060 PC Desktop
I have a presario 2500 laptop and it will start go to the windows xp loading screen then will go to a blue screen with just the windows xp logo and cant do anything after that but move my mouse
click f5 before xp starts to load. choose halt on error and record code. google that code. most often it is a bios error after a new install (memory...etc.) sometimes you can boot into safe mode to undo a recent change. if all else fails reinstall...could be bad hard drive boot sector also.....check code first
Aug 04, 2009 | Compaq Presario 2100 and 2500 ,NX 9000...
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
Computers & Internet Logo
81 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
