Question about Sony Acid Music Studio 7 Full Version for PC (SAMS7000)
Acid 7.0 music recorder
Im trying to use an external microphone to record on my acid 7.0 and when i click the record button or arm to record it says it has had an error recording and doesnt work. any suggestions?
  • 38 Answers
It sounds like the software is having trouble locating a recording device. If you go in to the settings for the application, you should be able to select/see the audio input devices. Does the device you are trying to record to show up and is it selected as the active recording device?
Posted on Mar 20, 2009
Friends say When i speak sounds like Static any 1 know how to change setting or find it in computer. Im using Satellite Fusion
The external microphone itself could be the culprit, or its connection to the 3.5mm port could be flaky. To test the theory do this:
1 Connect an external microphone to the computer.
2 Click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder.
3 Click the Record button and speak normally into the microphone.
>>>> WIGGLE THE CONNECTION AT THE LAPTOP OR FLEX THE MIC CABLE WHILE RECORDING. Maybe even narrate what you are doing while you record your voice. "Flexing cable near mic, now near plug..." <<<<
NOTE: You can only record 60 seconds at a time.
4 When you have finished recording, click the Stop button.
5 To hear what you just recorded, click the Play button.
6 To save the file, select Save from the File menu.
>>>> If you hear crackling in the playback that correlates with your handling of the cable then bad seating or a bad cable are the problem. <<<<
Adjusting recording quality
The better the quality of the recording, the more disk space the sound file requires. Experiment to find a balance that fits your needs.
1 Open Sound Recorder, if necessary (click Start, point to All Programs, Accessories, Entertainment, then click Sound Recorder).
2 In the Sound Recorder window, click Edit, then click Audio Properties.
3 In the Audio Properties window, adjust the Sound Playback quality and volume, and the Sound Recording volume.
4 Click OK.
Your new settings take effect the next time you record.
Dec 30, 2010 | Toshiba (P000257700) Microphone
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
  2. Click Record (the red dot) and speak into the microphone.
  3. When you are finished recording, click Stop (the gray rectangle).
  4. To play back the recording, click Play (the gray arrow pointing to the right).
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
  1. Access sound properties:
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  2. Click the Audio tab.
  3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
  4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
Recording second track
have you tried pressing the record button on the first track arm to stop it recording?
Jul 04, 2009 | Sony Acid Music Studio 7 Full Version for...
My internal microphone doesn't work
If you are refering to the internal microphone on your computer then try this. Open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound waves in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work your internal microphone may not be working or your computer may not have come with a built in microphone.There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 17, 2009 | Audio Players & Recorders
Microphone
Inspect your computer to see if has a hole somewhere that might look like a microphone. If you want to find out for sure open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound wave in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work you probably do not have a built in microphone. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Can't hear MIC through HEADPHONES in real time
Hi
i hope that you have the audio drivers installed and working and of course tested with your headphone..best way to do this is to play any song in media player and monitor it on your headphone...
the default settings for most DAW( Digital Audio Workstations) including ACID will be to mute the audio output when recording. This primarily is done to avoid feedbacks during recording. Anyways coming to the point. Since people would like to hear whats been recorded there is a scheme called as direct monitoring. I believe in ACID it is called as "Input Monitoring" and it basically is a small speaker shaped icon that appears next to the Record Arm Button once it is armed. Click on Input Monitoring and make sure its turned ON. Now you can listen while u record.
Hope this helps...contact me if u need further help
Jan 19, 2009 | Compaq Presario Notebook
Not able to record vocals
Make sure everything is routed correctly in Windows. Double click the speaker icon on your taskbar, go into options, click preferences. You will have the option to view playback or recording settings and levels. Select recording and click OK. This will allow you to select which inputs are active for recording.
If it still doesn't work, make sure you have Acid configured to your sound card. I am not specifically familiar with Acid, but all audio programs need to be configured specifically to the system that they're running on.
Dec 19, 2008 | Sony ACID Pro 5 for PC
No sound coming through speakers from microphone
ok i have windows vista so u have to right click on sound icon speaker then click playback n select conexant high definition smartaudio 221 n right click it as default n u gotta re load up acid then right click n insert audio
Dec 14, 2008 | Sony Acid Music Studio 7 Full Version for...
Samson G-track
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Sony Acid Music Studio 7 Full Version for PC (SAMS7000) Logo
312 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
