Question about Sylvania Circuit Breaker
Living in a double wide and am having problems with the circuit breakers tripping frequently and the breakers seem to very warm to touch. Is it possible the breakers are wearing out and should be replaced?? The unit was built in 1974.
  • 4,234 Answers
If the power used through a breaker exceeds 80% of its rating for an extended period of time, the internal parts will start to degrade. This can result in one of two possibilities:
1) The breaker will trip with a load less than its rating (your case)
2) The breaker won't trip at all or only under severe over current (not good!)
Given the age of your unit, I would suggest that you invest in new breakers, These should be available for no more than $5-$10 each depending upon the current rating. Also check for any corrosion inside the breaker box. That also will account for some of the heat you are feeling, I would also suggest that a licensed electrician inspect the box and wiring for any other signs of degradation.
Dan
Posted on Feb 19, 2009
Rainbow pn-2e circuit breaker
The circuit breaker could be defective.
Aug 19, 2016 | Rainbow E series Canister Wet/Dry Vacuum
A c trips frequently
this sounds as though something is shorting out . it could be the motor or the compressor. when it trips again feel the plug is it warm? aalso touch the breaker is it warm to the touch ? It could also be a bad breakre But I need to know all this to narrow it down for you? Let me know Jon
Jul 31, 2011 | Hyundai Heating & Cooling
Powerstar 115 tankless tripping reset ontop of #2 heat chamber #1 does not get overly warm mainly because of incoming water temp. but #2 seems to be heating after water flow stops to hot to touch and...
I don't have specific suggestion for tankless tripping breaker or if that is a circuit breaker problem or a tankless problem.
1) Move wires to another same-size breaker and see if problem persists.
2) Compare amp draw on tankless label with wire size and breaker size amp rating.
For example 30 amp breaker using 10ga wire is rated for 80% of listed amps or 24 amps.
3) If you are drawing full 30 amps, then 30 amp breaker is getting hot. Breaker trips with heat. Older breakers can trip more easily.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) Before calling service technician, open following link for Bosch troubleshooting steps.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
5) Be sure to read manual for yearly maintenance requirements.
6) Add a tempering tank for incoming cold water problem.
http://waterheatertimer.org/Tempering-tank.html
7) All gas tankless brands can be repaired by homeowner for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Apr 22, 2011 | Bosch PowerStar AE115 Tankless Water...
LD3600WV MAIN CIRCUIT BREAKER
I'm not sure what your question is - since all you did was put in a model number of a circuit breaker.
If you need to reset this circuit breaker: 1) Slide the handle to the OFF position. 2) Slide all the other breakers in the panel to the OFF position. 3) Stand to the side (not directly in front of the panel) 4) Slide the handle of the main breaker to the ON position. if it trips, there is a majot fault that should be addressed by a qualified person (electrician).
If the main breaker does not move to the TRIP or OFF position: 1) One by one, starting with the double wide / large value circuit breakers, slide the handles to ON. 2) Any breaker that goes to TRIPPED or OFF should be attempted to be reset ONCE. If it trips again, an electrician should be called, and the breaker left in the TRIPPED or OFF position. 3) One by one, return the handles of the remaining circuit breakers to ON.
If you're looking for different information - please provide as much detail as you can. Include the breaker panel manufacturer's name and model - and the circuit breaker data.
Mar 09, 2011 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
Circuit breaker trips frequently. It is a double 20 amp switch.
Is this breaker connected to water heater?
1) A double 20 amp breaker is called a 240Volt breaker.
20 amp breaker is actually rated for 16 amps for safety margin.
It is also important that this breaker have 12 gauge wire which is color-coded yellow.
Look at label on side of water heater for wattage of unit.
2) For example 4500 Watt water heater is typical.
4500 watts divided by 240Volts = 18.75 amps which is nearly full capacity for the 20 amp breaker, and is slightly above the safety margin.
http://waterheatertimer.org/B220C.html
3) If breaker is getting old, and it works at full load each time water heater is on, it can wear out.
Open circuit breaker box and replace breaker:
4) You can also move circuit breaker wire to another same-size breaker and see if problem continues.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a 2003 clayton double wide. I recently did
Can you check and see if there is a GFIC in line somewhere tripped.
It sounds like a ground fault receptacle has tripped somewhere in the circuit.
May 24, 2010 | Hammering
I wired a new dura-glas pump as a 115, and it popped the breaker. I put the black wire on 1 and the white on 2. Should I have wired it as 230? Should I switch the black and white wires, even though the...
The wire placement does not matter assuming you have a 115 volt supply with a three wire cord/cable and they are comming in as blk=hot, white=neutral and copper=ground.
Tripping a breaker would be from a shorted hot wire so look for a place where it touches the white or ground wires or the metal of the motor. Another cause would be if you really have 230V across the black and white and you connect it to a motor set for 115V. Is the breaker that turns off the circuit in question a signle wide or a double wide breaker. A double wide would be 230V.
Jul 31, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Breaker tripping
The problem may not be with your dryer but with the circuit breaker...
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 14, 2008 | Roper REX4634KQ Electric Dryer
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Sylvania Circuit Breaker  Logo
199 people viewed this question
Top Sylvania Electrical Supplies Experts
Steve
jdthefixer
 Kenneth
Kenneth
Are you a Sylvania Electrical Supply Expert? Answer questions, earn points and help others
