Question about Sony Dual Shock 3 Controller for PlayStation 3
Dualshock 3 sixaxis why does it always need to be plugged in
With the USB cord?? Isn't this suppose to be a wireless controller? i tried resetting the controller.. But still wont work.. i went to my Playstation 3 controllers settings and set the controllers to there right settings.. still nothing.. any help from anybody would be helpful.. thanks.
  • 3 more comments
  • chimmie2003 Feb 25, 2009
    Thanks for trying to help. The controler only works though when plugged in with the usb cable... i unplug it and it doesn't work.... i did as u instructed above... any other thoughts or ideas??? do i have the wrong controller or something?? is there maybe certain models that work??
  • Anonymous Mar 01, 2009
    I have the same problem. The controller LED's continuously flash red and do not connect. when I plug the controller in, it works fine. The lights flash slowly compared to when it is connecting.
  • Anonymous Mar 11, 2009
    I am having this same problem. My PS3 said it needed to reset itself. It did so, only now my controller will only work if manually connected using a USB cable.
  • Anonymous Mar 13, 2009
    mine does the same thing, my other controller works fine.
  • pjtr86- Apr 16, 2009
    have the same problem to. It worked fine until i was away for a couple of months and when i came back the controller is completely dead without the usb plugged in. When plugging in the usb-cable it says the battery is charged but as soon as I unplug it it's dies again.
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Posted on Sep 23, 2010
  • Tom Ewing Mar 13, 2011
    When I try this, the console will turn on, but then I get the 4 blinking lights again once started up. Any other ideas?
Hi have the same problem where the controller has to be plugged in to work....but have managed to solve it by complete luck! when it is plugged in and connected hold the ps button down and take out the usb, keep the ps button held until the 1 red light stays on which means it is connected. although once you turn the ps3 off you will still have to turn it on by the power button on the ps3 and then repeat the process. hope this works for you guys!
Posted on Oct 14, 2009
    Problem Solver:
  • 5 Answers
Once the controler is connected with the usb cable and the system on have you try-ed unplugging the controler the 4 lights on the controler should flash a couple of times and the establish connection if that dont work contact my at swinginflames@gmail.com hope it works:)
Posted on Feb 24, 2009
Tip
Connect ps3 to PC
<span> <li> <p>Plug the mini-USB port end of the USB cable into the PlayStation 3 controller while connecting the standard USB port end of the cable to your PC.Wait for Windows to report that it has "Detected New Hardware" and let Windows go through its full scan. When Windows says that it could not recognize the hardware, the scan is complete.Download the appropriate drivers for your controller, either SIXAXIS or DUALSHOCK 3 (it is written on the top of the controller). These drivers can be found on several websites by doing a Google search for "PS3 Controller PC Drivers."Unzip the driver files from the zipped folder to someplace easily accessible on the hard drive (such as your desktop).Double-click the Setup icon and follow the directions given on-screen to install the SIXAXIS drivers.Unhook the controller and reset your computer to complete the installation process.<br /></li><span><br /><br /></span></span>
on Dec 06, 2010 | Sony Playstation 3 (PS3) Console
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
Dualshock sixaxis troubleshooting wired and wireless does not work PS3. I try to wired control from another brand not sony and works.How i know if the console is charging the controls?
while the controller is plugged into the system with USB cord try the reset button on the back of the controller (next to the center screw on top).
Jan 03, 2011 | Sony Dual Shock 3 Controller for...
Hi, the wireless controller, a sony dualshock 3 sixaxis, won't stop vibrating. Any solutions? thanks, Angela
If you've already removed the batteries and replaced them, then I think there is a small hole on the bottom you could stick a paper clip into an press a button to do a reset. You may have to re-sync the controller with the console after doing this. I don't have one of these, but I've heard of doing this before.
Sep 20, 2010 | Video Game Consoles & Games
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Sixaxis controler won't vibrate
The SIXAXIS controller will not vibrate by design.
You must have a Dualshock 3 controller.
If your controller says dualshock 3 on it and it does not vibrate, you should see if you have any warranty support or if you can replace it.
May 04, 2009 | Video Game Consoles & Games
Sixaxis on ps2 ???
No, it's not possible to hook up sixaxis to PS2. Sixaxis is a part of DualShock 3 for PS3 which is an optional feature in the PS3 games. Playstation 2 controllers run off of DualShock 2. So sorry, but you're gonna need a PS3 for that.
Jan 29, 2009 | Sony PlayStation 2 (PS2) Console
Dualshochock 3 controller
On the back of the controller there is a very tiny rest button.
Press and hold for 5 seconds.
Then reconnect to PS3. It should work.
This fix came from Sony Tech Support.
Dec 21, 2008 | Sony Dual Shock 3 Controller for...
Sony Dual Shock 3 Controller for PlayStation 3 Logo
1,841 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
