Question about SanDisk Sansa e250 MP3 Player
E250 startup problem
E250, When charging screen stays lit. After a while I unplug it, it stays lit. I hold the rec key down 15-30 seconds it goes off. then I hold rec button as I connect to computer. It powers up and goes to refreshing base for about 3 seconds then shuts down and I have to start all over again to no avail.
  • George Hadley Feb 20, 2009
    I can't believe it. I almost threw my e250 mp3 player away and bid on Ebay for another. I worked on this problem for 3 days. It's a very tricky solution, but after a number of tries it started refreshing then shut down. When I plug it in to my PC it started up beautifully. Thank you so much. I really like my player and would have not been happy to toss it.
  • 8,596 Answers
Download the Sansa Recovery Tool, and then repeat the same procedure that you followed above.
Posted on Feb 20, 2009
My e250 will not turn off & will not turn on-Screen is gray w/vert. lines in it
You need to remove the battery and let the system power down completely. I have had this problem and the others I have seen on this site. Removing and reinstalling the battery solves many problems. Just letting the battery drain is not good for it and may take a really long time.
Sep 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250
hi follow these instructions ok
1 with mp3 player off switch lock/hold to on
2 press and hold down rec button on left hand side keep holding down
3 switch on whilst still holding down rec
4 it should now say recovery mode
dont do nothing just yet dont connect to computer ok first goto sandisk website and download the latest firmware once downloaded open the file and it will tell you how to install this onto mp3 player.
you should no longer have your problem
let me know how you get on and also if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 ask me this
Solution:
1. Put Lock on.
2. Push and Hold Both Rec and Power buttons while the power is off.
Then message should show saying: " Welcome to Recovery Mode"
Mar 17, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250R not working
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
let me know when you get this far ok
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Screen color messed up, won't connect correct
well can you come into recovery mode? hold(activated) push rec button and hold it while start your mp4 if it works get me information about it..
Feb 01, 2008 | SanDisk Sansa e250 MP3 Player
Scandisk Screen
hold down the power button for 20 seconds
Jan 31, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250, will not charge...
when you unplug it try holding the power button for 20 seconds or more.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
My sansa wont boot up
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 "refresh database" error
Sounds like your music may have become corrupt.
You can follow these steps to erase and start anew.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 09, 2007 | SanDisk Sansa e250 MP3 Player
Hello. Seems like your player is encountering either a file or system error, causing it to freeze. One solution would be to see if your player would be detected by your PC, then attempt to format it. Another solution would be to re-apply the firmware. Here are the steps: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
