Question about HP DeskJet 5550 InkJet Printer
Change the ink cartridge
I need instructions on locating the ink cartridges...so I can replace them.
    President:
  • 2,692 Answers
How do you replace the ink cartridges, i am following the instructions, but i must be doing something wrong, the thing will not stay out so i can change them?
You should be able to open and close the cartridge access door, this should automatically trigger the carriage assembly to move to the middle where you can change the cartridges. After a few minutes most printers will typically move the carriage back due to inactivity.
Please note our Inkjet411 site is a self-service sitelet which provides over 80 videos of do-it-yourself printer remedies and corrections: http://inkjet411.com/
Ink Cartridge Refill Store Map Locator: http://www.go2ris.com/#retailpartners
If you need to purchase new ink cartridges, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Aug 15, 2014 | Office Equipment & Supplies
How do i change the ink cartridge
    • Make sure the printer is plugged in and turned on.
    • Grasp the front top of the printer. This is the Scanning Unit Cover.
    • Lift the Scanning Unit Cover gently until you hear a click. The cover will remain open by itself.
    • Wait while the cartridge holder moves from the left to the center of the printer. The ink cartridges are located in the cartridge holder.
2. Then from there you just need to remove each individual ink cartridge and replace it with your newly purchased cartridges. Be sure to replace each one in it's appropriate location!
Jul 24, 2011 | Canon Pixma MP480 All-In-One InkJet...
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
On Epsom Stylus NX110 I cannot get the cartridges to the change position If I go into cartridge replacement utility I cannot open that and do not have a printer in the lower right hand corner to access...
Here is what I found on Epson Web site. Click on link below. IF YOU FIND THIS HELPFUL PLS RATE ME. THANKS AND GOOD LUCK......
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=128285&prodoid=63083739&category=Products
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Replace Cartridges Using a Printer Software Utility
For best printing results, use up a cartridge within six months of opening the package. If you need to replace a cartridge when the ink light is flashing or off (before the cartridge is expended), you can run the Ink Cartridge Replacement utility.
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
You see one of these screen SEE ATTACHMENT BELOW
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary
Mar 21, 2010 | Epson Stylus NX115 All-In-One InkJet...
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
Mar 21, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
How to change ink cartridge in epsonnx110
Jan 01, 2010 | Epson Stylus NX115 All-In-One InkJet...
Can you let me know where to locate the ink cartridge on the hp 1410,i cant find it to change it
Turn the printer on then open the front cover.The carriage with the cartridges will move to the center and you'll can change the cartridges.
Nov 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
I want to change my black ink cartridge and never do that !
Here you go - detailed instructions on how to change the ink - link
Dec 08, 2008 | HP Officejet 5610 All-In-One InkJet...
Changing cartridges
Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
Dec 11, 2007 | Office Equipment & Supplies
HP DeskJet 5550 InkJet Printer Logo
88 people viewed this question
Ben Johnson
