Question about Linksys Wireless-G Broadband Router
How do I remove linksys broadband WRT54GS Wireless-G router from my pc. and revert to just my Motorola, SB5101 surfboard cable modem. Tried simply removing the router and pluging the modem back in, but no connection ?? Is this a simple thing to do myself ?
  • 728 Answers
Hi intriguedkiw;
Yes this is fairly simple. Open up your network connections and delete the icon for the local area connection to the Linksys router, and click on Add new connection to create a new connection to the Cable modem. The add wizard will walk you through connecting to the modem, just fill out the questions correctly, and you should be good to go.
Good Luck,
Mark
Please dont' forget to leave a rating.
Posted on Feb 19, 2009
What kind of router do I need to get so I can get wifi out of a Motorola Surfboard SB5101 Cable Modem ? My PC isn't wifi compatible but I have other equipment that are.
You will want to get a "Wireless N" Router, also known as an 802.11n Router. Price range is up to you, but here is a relatively cheap one that performs well: http://goo.gl/Szjovd
Dec 18, 2013 | Arris SURFboard® SB5101 Cable Modem
How do I bypass my router and connect my motorola sb5101 to my laptop?
use an ethernet cable and connect the modem with your PC
power cycle the modem to make it recognize your PC
At your PC, http://192.168.100.1 with username and password admin/admin to check the result. If your PC cannot get to that IP, you need to use ipconfig /renew command or simply reboot your PC.
Oct 31, 2010 | Arris SURFboard® SB5101 Cable Modem
Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Jun 08, 2009 | Arris SURFboard SB5101 Cable Modem
Hi I am going to hook up a linksys wireless router and i need help. do i just hook it up or do i have to do something to the modem first?
all you need to do is to connect the ethernet cable to the internet port on the back of the linksys router and then plug the routers power cord into the wall and you should be ready to go.
Jan 03, 2009 | Arris SURFboard SB5101 Cable Modem
MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Dec 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Moto modem to Linksys wireless router
You have to reset the modem from behind (little pin hole) with the modem and router not connected via ethernet, the let it restart and reset the router after both are reset connect the ethernet cable between them.
Nov 21, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Need tech advice
No and why doesn't your internet provider... provide a cable modem?? Did you just ask them to enable broadband internet service? So now you'll have to provide your own cable modem.
If what you say is correct you need a cable modem like a motorola surfboard from BestBuy.... then the cable modem plugs into your Linksys router and your PC's plug into the linksys router also.
http://www.bestbuy.com/site/olspage.jsp?skuId=8229044&st=motorola+surfboard&lp=1&type=product&cp=1&id=1168043113583
May 05, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
103 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
