Question about Dewalt 4 1/2 High Performance Masonry Blade DW4725B
  • 360 Answers
The instructions are available --->click here<---
Please take the time to give this solution a fix ya rating
Posted on Feb 19, 2009
I have a Dewalt DW321 corded jig saw. I can't get the blade to release. The blade blade holder seem frozen.
place the shaft in the fully up position and give the collet holder a tap to move it back up further
sometimes they jam from metal, dust and grit
sometimes a bit of WD-40 or like item will lubricate the movement and make it easy to pull up
Nov 18, 2017 | Dewalt Saws
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ... > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Dewalt jigsaw (dw321) how to change the blade
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4".
Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once
it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller.
Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Dewalt Saws
How do you change the blade in a DeWalt Jig Saw Model DW321
  1. Lift the black handle/knob approximately ¼”.
  2. Turn the handle/knob counterclockwise 5-7 full turns until blade chuck is completely open, keep the black knob pulled up as you turn it.
  3. Insert “T” shank or universal jigsaw blades into the chuck making certain that the back edge of the blade fits into the support roller. Please note that when using “T” shank blades, insert the blade to the shoulder of the shank.
  4. With the knob/handle still in the up position, turn the handle/knob clockwise until the knob starts to ratchet.
  5. Push the handle/knob down. The blade is completely installed at this point.
Jun 11, 2010 | Measuring Tools & Sensors
Change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Jan 18, 2009 | Saws
Dewalt 4 1/2 High Performance Masonry Blade DW4725B Logo
194 people viewed this question
Top Dewalt Saws Experts
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
