Question about HP Compaq Evo N800w Notebook
Replaced drive in evo n800w stats to flashing
Replaced drive in evo n800w. It starts to flashing cursor
In stat lists my list starts at l2. how do i start at l1
Press the [STAT] key.
Use arrow to move cursor to SetUpEditor
SetUpEditor command echoes on main claculator screen.
Press [ENTER]
Calculator will answer Done
Press [STAT] and select [1:Edit]
Type in the values in your lists.
May 13, 2010 | Texas Instruments TI-84 Plus Calculator
My hard drive I can't Format
It depends how your tring to format it. If your operating system is running on the same drive it will fail. You would need to boot off another OS or boot of the XP / vistra CD and format it via the installation wizards.
Jun 08, 2009 | HP Compaq Evo N800w Notebook
Reinstall XP on Compaq Evo N1000e - XP disk will not boot
Use a program to write zeros to the drive. Your hard drive manufacturer provides a program to do this. Then format the drive and then install your XP
Apr 26, 2009 | Compaq Evo D510 Minitower (Open Box)...
Replace hard drive
That's correct, I figured it out, more like stumbled across the drive and how to remove it.
Ron
Jun 09, 2008 | Compaq Presario Notebook
Compaq EVO 610 startup
replaced mainboard solved.....
May 06, 2008 | Compaq Evo N610C Notebook
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Nov 13, 2007 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
HP Compaq Evo N800w Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
