Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
My wireless deviec linksys working properly. but i am not able to connect and configure by defauult ip address 192.168.1.1. before reset the device was accessing by 192.168.1.1 but not working. after reset it is working but not accessing.
  • Suraj M
    Suraj M May 11, 2010
    Hi...
    Please access with Default gateway IP address currently you are using for your computer...
    let me know the output.
    Clarification request:
    Do you have Console cable (one side Serial 9pin and other Side LAN pin or RJ45 PIN) we can configure router with that when default IP address fail to access?
    Regards.
    Suraj
  • 611 Answers
Your pc firewall is enable? diseable it and check the cable
Posted on Mar 06, 2009
  • kalpesh jain
    kalpesh jain Mar 06, 2009
    check this any antivirus is enable or what ithen disable for few min for the configuration
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
It does not make much sense. But it seems the WAP610N has a limit on concurrent connections. We just started to use this device in a small office network. There are about 15 laptops on wireless...
Two possibilities:
1. the router is configured to hand-out IP-addresses in a limited range, e.g., 192.168.1.100 to 192.168.1.110, namely 11 different IP-addresses. When the 12th computer asks for an IP-address, there is none available. Remedy: configure the router to use a larger range of IP-addresses.
2. when an IP-address is handed-out, attached is a 'TTL' ("time to live") value, indicating how long the IP-address remains valid, e.g., 10 minutes or 100 minutes or 1 day or 1 week. If the TTL is too large, then each computer "hogs" the IP-address (even after being shut-off in mid-afternoon).
Remedy: configure the router to use a shorter TTL. Don't worry: when a TTL value drops to 50% of its original value, on a specific computer, the computer will "renew" the lease.
Mar 18, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
Can't communicate with Linksys WAP610n from laptop via straight or crossover cable. Fixed IP network won't find WAP610n either.
If on Xp go onto start then run in run enter cmd this will open a command prompt in dos
then type in ipconfig and check settings if the ip and dns settings seem incorrect then type ipconfig/release then ipconfig/renew this will reset the system hope this rectifies your problem
Mar 01, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
Linksys Access point
simply reset the access point and configure it again from start. and it should work
Apr 30, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
How to configure linksys wireless-g 2.4ghz broadband router i am using windowes xp,i have two LAN card in my pc.through internet sharing i connect linksys wirless router.wifi is working fine .i am able to...
try to factory reset your linksays and then connect your device.
after connection of your device re configure your linksys again with 192.168.1.1 IP address
Mar 16, 2010 | Computers & Internet
Need help need help with WAP54g access point with WAP54g access point I recently had to help try to fix a small office network. Currently it has a netgear ds116 hub with a wap54g connected to the hub for...
Hey !
you said that you that you reset the WAP54G , the default IP address address of WAP is 192.168.1.245.
The IP address that you tried ( 192.168.1.1 ) must be the IP addres of the sonic firewall which might be acting as a DHCP server.
To access the WAP54G set up. you will need to connect the computer to the HUB and the WPA to the hub with the cable and then try to access WPA with the IP address 192.168.1.245
Click Here for more info about Access point
Oct 07, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WGA54G ver.1 cannot find
Try to use the game adapter as your wireless adapter to test if it is still working. Connect the game adapter to your PC and then configure it manually. Assign a static IP address on your PC same range as your game adapter and then configure the wireless settings same as your router. the Default IP address of the game adapter is 192.168.1..250.
Jul 04, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
Can't find IP address
You can get the ip-address by visiting this http://www.ip-details.com/ .It's used to search and find ip address's,domain name host's whois information including city, country, global latitude & longitude coordinates.
Jun 08, 2009 | Arris WA840G 802.11g/b (49832000100)...
Installing a Linksys Access Point to a Verizon Actiontek wireless router.
The IP Address of WAP54G is 192.168.1.245
Connect a computer to the Access point.
Assign a static IP Address to the computer, like : 192.168.1.10 , the subnet mask should be 255.255.255.0
Open the setup page of the Access point, by typing 192.168.1.245 in Internet Explorer / Firefox. Configure the wireless settings, Change the IP Address to the range that of the Actiontek router.
Save settings. To know about wireless security, click here.
To check the latest update on Linksys products, click here.
Hope that helps :)
Mar 28, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Computer found router before why doesn't it now?
Download Network Magic (no need to buy, free one will work) once installed look at your network map, you should see your router click on it and note the IP address. Type this address into your browser.
Dec 09, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
118 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
