Question about HP OfficeJet 7410 All-In-One InkJet Printer
How to hook up this printer wireless to my main computer
I have a new desktop computer HP , wireless router Netgear, an HP wireless printing upgrade kit.. the hp program already installed in the new desktop, as well as the HP wireless kit... I would like to hook up the HP printer WIRELESS via the ROUTER to the desktop. Please help. my dell computer used to print to my wireless printer. All of a sudden it lost the ability to connect.
  • Tobamarks Mar 01, 2009
    I am able to print from my desktop but not from my laptop.
  • Suraj M
    Suraj M May 11, 2010
    Hi..,
    Please clarify my requests below:
    1.What is the IP address and Default gateway of the Computer
    you can see IP address by doing as below:
    Click on Start >> Run >> type cmd
    black window or command prompt will be opened.
    Now type ipconfig (let me know the output)
    Ex:C:\Documents and Settings\essbmcghial>ipconfig
    2.What is the Printer IP address you can go through printer Menu >> Settings >> Network >> Wireles >> wireless settings for example.
    Let me know the IP address of the printer.
    Regards,
    Suraj.
  • 728 Answers
Hi jjank740;
First off, did you try to recycle your printer? Turn it off and back on again. Sometimes power outages can disconnect that printer. If that doesn't work. Go to the printer and access the system network configuration on the led panel. Type in the WEP number and password again, and let it search for the connection. That should do it. Once it's connected you'll see the blue wireless indicator turn on.
Good Luck
Mark
Please don't forget to leave a rating.
Posted on Feb 19, 2009
How do I connect my HP Photosmart C4795 Printer to my new Netgear N600 Router?
Hello Janet,
Please click Wireless printing center to access more info on how to connect you printer to a netgear router ( wireless )
Dec 23, 2013 | NetGear N600 Wireless Dual Band Router...
HP Photosmart C4780 and Acer Aspire fight over web-based printing!
Try hard-wiring your laptop to the router with an ethernet cable as a test and then try printing, if you do not loose connection to the internet then the problem is probably that the printing is hogging your wireless bandwidth.
If the same thing happens with loosing connection to the internet try connecting to the internet real quick through another computer that is hardwired, you want to find out if the problem is a wireless one or that affects wired computers also. You might need a driver upgrade, you also might need to upgrade the firmware of the router
Jan 22, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
Cannot connect to internet through netgear n300 wireless router
They are pretty straight forward. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Try resetting it by holding the reset in till it cycles through. This will clear all custom setting and try again.
I normally don't suggest firmware upgrades, but try updating.
192.168.0.1 Defual login if you cleared custom is User: admin Password: admin
http://www.downloads.netgear.com/files/DGND3300v2_UM_14Oct10.pdf
Other than that the unit is damaged / defective.
Oct 25, 2012 | NetGear N300 Wireless Router
I get a message that my HP 5500 is not connected to my new iMac but the printer says it is connected. How to solve?
The printer says that it is connected correctly to the router because the router is aware of it and has assigned to it an IP address on the network.
The computer on the other hand does not know that there is a printer. Not finding one (or not knowing where to look for it) the computer reports that the printer is offline.
You must install the printer drivers on the computer.
May 25, 2012 | Apple Computers & Internet
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
Can't print from computer to wireless hp printer
Go to Wireless Printing ' HP.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 04, 2011 | NetGear Wireless N Router wPowerline...
I what to share my printer with the other laptops in my home.
you can share the printer in your desktop.( lets call it computer A ) . When you want to print from computer B, go to Start - Run - type in \\ computer A or its IP address and print from there.
Thanks
Ranjit ranjit@supportminds.com
Aug 06, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Setting up printer on home network
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Apr 13, 2009 | Computers & Internet
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
NETWORKING
yes of course you need a wireless router for that. wireless router are for wireless network (desktop pc also needs WAN)
Feb 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
340 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
