Washing machine lid is down but beeps as if its up.
When my machine lid is down, it beeps as though the lid is up, i was having to add extra weight to the lid to allow the machine to wash but was regularly stopping as though the lid as been lifted but was still down. I have to move the weight around and it keeps washing til next time. Today i lifted the machine lid up and a lot of rust? came out of the little plastic thing on the inside/ left side. i am not sure wat the rust? was, but i removed it and now my machine lid acts as though its permantly up.
  • 188 Answers
Either the lid switch is defective (replace it), or the cabinet is rusted enough the the switch is not seated properly from movement and it's not engaging with the lid strike.
Posted on Feb 19, 2009
My washing machine has started beeping during the wash cycle - why?
Try running the same wash cycle with no clothes in the machine, just the water.
If it does not beep you are overloading it or the load is unbalanced.
Dec 20, 2015 | Hotpoint Aqualtis AQ113F497E White 595 mm...
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
The washing machine does not run unless we put weight on the lid
Your lid switch will have to be replaced.
Paste the video link below to see how to access the cabinet to change the part.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Is there a reset button for my Whirlpool Cabrio Washer? Every time I start a load of laundry to wash, the washer puts the cycle on pause at least 5 times. I have to hit start, wait for it to beep, hit...
Check the lid switch and its actuator on the lid. The pause you're getting is likely an open lid sensed by the washer control. Also try to push and pull the inner tub up and down a few times - if I remember correctly these washers have a floating basket, which engages the gears when there is enough weight inside. If there is not enough clothes it may not wash correctly (I don't remember exactly, but try it anyway, what do you have to loose? ;) ).
Nov 02, 2009 | Washing Machines
Our washing machine was stopping at various stages & would beep and just not continue with the cycle. (Sometimes it would fun a full cycle without a problem however). We took it to an official...
The drum suspension rods may be worn or one of them may be brocken, throwing the drum out of balance.
They are fairly easy to change if you know how to open the top hatch. Check and remove them individually.
Let me know if you need assistance or more info.
Ash
Oct 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
I have a Simpson 22S750M 7.5kg eco washing machine problem is that it doesn't drain the water on the last cycle as it thinks that the lid is not closed even though it is, the beeping is driving me nuts...
we have had the same machine for a few weeks and have the SAME exact problem. They are replacing the whole electronics board but the part has to come from SA and will take a week at least. I have an incont child and this is very hard! why dont they recall?
Sep 18, 2009 | Washing Machines
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
