Question about Bose SoundDock Digital Music System for Apple iPod - White
I have a lifestyle system with surround sound at central location and two remote rooms connected through two additional amplifiers. The central location works perfectly well. Recently, I started getting ticking sound coming from the right speaker (in both rooms !) in the remote locations. Any ideas how to fix the problem ?
Probably the connection in the main room to the wirless transmitter. The problem is definitely between the media centre and the wireless sender as it is not effecting the main zone and is effecting both second zones. Multi pin connections can bend very easily if pushing the connection further in does not solve it you may need to replace the pins. why not call Bose tech?
Posted on Mar 03, 2009
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
I had Bose lifestyle V35, V20 try to link together. Bose link AL8 transmitter will not connect to receiver. both led is light solid green. Please help.
The commands for the Bose link system are actually going through the remote control system. In order to use the system you need not only a set of AL8 sender and receiver, but also a special remote control model RC48S2-40 these model numbers are slightly different for the US and for Europe. In addition you will need to activate the BoseLink connection through the system settings menu and you will need to tell the remote to which system it needs to talk. When you have done all that, there should not be any problem to "connect" the two systems. If this does not work, you may need some specialized help from a Bose specialist who understands this multi room set-up.
Nov 09, 2014 | Bose link AL8 wireless home-wide audio...
My HDTV does not have RCA audio out option to connect to my Bose Lifestyle 12 surround system. Can I connect the Directv box directly to the lifestyle12 system to get surround for the TV? I would do...
Just make sure that you are using compatible connectors and that your signals are compatible. Ie. analog out to analog audio input, digital audio to digital audio input.
Sep 21, 2017 | Bose Lifestyle 12 System
We have just installed a Bose lifestyle system, with SA 2 and SA 3 amplifyer, with a second set of speakers in another room. we cannot get sound to the second room. the second remote is not responding....
Make sure you unplug your sa 2 and sa3 amplifiers after setting the codes. Wait at least 60 seconds, then plug back in. I would also unplug the in and out boselink cables as well. Once youve waited for a minute, then plug everything back in. Should work. If not, call Bose technical support. They are really great. I have 15 SA 3 amplifiers throughout my home. They are great.
Mar 21, 2010 | Bose Lifestyle SA-2 2-Channel Amplifier
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
Standard amplifier + Bose Lifestyle 12 Acoustimass module
well u didn't include any models # for the proton or "cubes" so all I can speak too is a simple heads up lesson about amp loading , most modern integrated amps look for a 4 ohm load for its speakers , this is saying total load , so if one was to connect say two speakers (plus to plus and minus to minus) assuming the speakers are 4 ohm already this would divide down to only 2 ohms (this would heat up the amp and affect it working ) but also if the speakers are say 8 ohms each then this divides down to 4 ohms (and the amp would see two as only one ) , also wire length between speakers counts as well , assuming most speaker rated size wire is say .023 ohms per foot this would also have to be added to the total load the amp see's , there are far more technical ways of running longer wires to other rooms but this involves impedance matching transformers and the like . so I'll not discuss them
May 26, 2017 | Bose Lifestyle 12 System
Increase output of Lifestyle 18
apologies mate but what you hear at maximum volume (set volume to 99) is what the system can generate... The Lifestyle system are designed as stand-alone out-of-the box system and like other systems will only perform to their defined level. The only way is by using the AUX out (located behind the DVD/media center and connect either a pwoered loudspeaker or another amplifier (note that the output is fixed line so choose an amplifier with volume setting knob). with multiple loudspeaker of your choice. You may also go and buy expansions speakers from Bose itself
Again, glad to be of service...
Feb 06, 2009 | Bose Lifestyle 18 System
No sound from 1 station
Suggest a set-up procedue once again and see if that helps...accordianman
Jan 17, 2008 | Bose Lifestyle 38 System
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Bose SoundDock Digital Music System for Apple iPod - White Logo
197 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
