Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Panasonic rear projection tv air filter
We replaced the lamp on our tv and soon after that, the red temp button started blinking and a box showed up on the screen stating "tv will be turned off in 1 min. air filter needs to be replaced." we cleaned the back of our tv but are unable to locate the air filter. Now the tv won't even stay on at all. Please help!!
  • Will
    Will May 11, 2010
    is this a DLP?
    when you replace the bulb it must be as clean as possible otherwise it could develop hot spots and cause premature failure.
    -good luck-
    Will
    compressionconnector.com
Heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Posted on Feb 28, 2009
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
HI,
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Robert
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I have a Panasonic Model PT-50LC13 flat TV. Was working when got it brought it home, it is used and now when I go to turn it on --- we get a green light then a flash of 5 yellows blinks then no light for...
This tv has 3 indicator lights on front, Power, Lamp and Temp
I assume Temp light is blinking 5 times after every 5 seconds, if that is correct then it is problem of clogged air filter located in light engine that need to be cleaned.
Below is an image of light engine and air filters locations are marked with red circle, it is job of professional to fix this issue because complete light engine need to be take out from tv cabinet.
Hope these info will help you, let me know if you have additional question or need service manual copy if you want to repair tv by yourself.
Thanks.
Nov 10, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
Mar 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Power indicator light blinks orange times
sounds like the lamp faceplate is not screwed back in properly
Aug 01, 2008 | Panasonic PT-50LC13 50" Rear Projection...
My Panasonic PT- 50LC13 doesn't turn on
Your service manual on page 82 steps you through decoding the blinking
1) there are two lights on the front near the reciever of the remote signals (Temp indicator and Lamp Indicator)
2) If the Temp indicator is on then they recommend you contact a service center
3) If the Lamp indicator is on and the power light stays on (no blinking) then you need to replace the lamp. Otherwise it says to contact the service center.
4) Counting blinks with the lamp indicator (1 every 5sec - lamp will not light or is abnormal, 2 every 5sec - lamp voltage is abnormal, 3 every 5sec - lamp temp is too high, 4 every 5sec - other error)
Apr 26, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Josh
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
480 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
