Question about Sansui VRDVD5000 DVD Recorder/VCR
A DVD was left on pause for a long time by someone watching a movie. The player now has a red ring around the record button and nothing else. There is nothing in the display screen and it will not respond to any command either by remote or on the machine itself. HELP it is driving me batty trying to figure what is wrong!!!
  • 3 more comments
  • frappy11 Feb 20, 2009
    Unit is SAN0218-250GB DVD+RW Recorder. While watching a DVD my niece put it on pause and forgot it. Much later I tried to use it and it would not respond to any commands. I unplugged it for10- 15 mins then plugged it back in. It still would not respond, there was nothing in the display screen and a red light came on around the ch+-/rec on off switch. It will not respond to any command including holding the stop button in or unplugging for any amount of time.
  • frappy11 Feb 22, 2009
    Everyone...please the unit is NOT repeat NOT a VRDVD5000 DVD Recorder/ VCR.....it IS repeat IS a SANSUI DVD+RW Recorder model number SAN0218-250GB...and it wont respond to any commands given either by remote or by pushing the buttons on the front..there is power but I cannot get it to do any of the functions...It has now been unplugged for 3 days and when plugged back in it does the same as my originl description of the fault.
    dvd
    Please everyone READ what I am typing...your comments are irrelevant and stupid....can anyone understand what I am saying ?????
    The power cord does not come out of the back of the unit so I cannot do that!!!
    Hooray!!! Thank you for your explanation although it is not what I wanted to hear...I will arrange for the nearest sansui fixer to look at it
  • 350 Answers
Dear frappy11, Sun 02-22-2009 12:19am EST (USA)
RE: Sansui DVD Recorder-VCR Combo - VRDVD5000
You may want to contact Sansui direct @ http://www.sansui-global.com/english/contactus.php but I don't think you'll get anywhere! They don't have a great support system for their products as far as I can see.
Some DVDs and a lot of other things are built to break easily, offering no repair or troubleshooting support, and it's a shame!
When I find I've purchased such a product and it doesn't even pay to have it fixed (always worth getting an estimate though) I like to take it into the garage, put it on the bench and sludge hammer it to death or scavenge it for parts!
jack
A DVD was left on - a839dc5.jpg Please Rate This!
Posted on Feb 22, 2009
    President:
  • 2,559 Answers
This is due to an attempted recording that has stored files in the memory,You will need to remove the cover and take out the internal battery for a few minutes so the files in the memory will be deleted.
This can sometimes be done by unplugging the unit and holding the power button(while it is unplugged) until the unit de energizes(you will see the light come on and fade out)
  • 6,784 Answers
The main control has initiated protect mode. this may happen when the actual lens has burned out. when a DVD is left in the loading dock in the still mode function for to long, this will cause a reflective effect that will burn the lens out immediately. the main control will shutdown the entire dvd system during this event. unfortunately, it will have to be repaired by the manufacture in order to release the protect mode that exist.
Posted on Feb 20, 2009
  • 142 Answers
Hold the power button down while removing the power cord from the back of the unit. Now plug the power cord back in and restart the machine. Give it time to reboot.
All better?
Please remember to rate this solution.
  • 130 Answers
Well unplug it for 5 minutes it should reset good luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, unplug from the mains for an extended period of time. This is to revert the unit back to factory default and simulate a reset. Should that not be corrective, then pls:
  • post back to confirm if it is a Sansui VRDVD5000 DVD Recorder / VCR Combo;
  • if it is still under warranty;
  • if you are considering a DIY (do-it-yourself); and
  • if you a re familiar with electronic components & circuitry, use of a DVM and a soldering iron.
If not, then consider to seek the services of a qualified professional.
Good luck and thank you for using FixYa.Pls post back as requested.
  • 423 Answers
Have you turned it off and let it sit a few minutes?
  • Rob
    Rob Feb 20, 2009
    Honestly, not exactly sure in your case...but from my extensive experience with VCRs, leaving the unit on pause for an extended period of time can burn out the motor. When a "catastrophic" event like that occurs it can shut down the entire unit. Take it to an authorized repair shop. Sorry, there is not too much anyone here can do for you.
    Genius:
  • 1,011 Answers
Sir,
Problem related to dvd or dvd player? Whenever u can't use dvd player for 6 months the dvd lens will going be defective. So buy a cd lens / dvd lens cleaner and play it. the problem may be solved
thanks good luck
  • 547 Answers
Motor burnt out find replacement part or take in for repair
    Scholar:
  • 140 Answers
You need to uplug it for 5 min and plug it back in... It justs needs to be reset.
I want to record Turner Classic Movies from my cable to a dvd. I then want to edit out parts I don't want. Some movies are good but have just a few scenes that are not appropriate for family viewing....
The dvd recorder will not automatically edit out parts you don't want to see....the easiest way is to watch the movie live and if you know the part you don't want to record, press pause during the part and resume when it's done. Otherwise you will have to load the whole movie from dvd to your computer, get an editing software and cut out the scenes you don't want. There are lots of these simple programs on the market and some are even free.
Quickest way is to watch it real time and push pause on the objectionable parts.
Hope this helps.
May 05, 2011 | Philips Magnavox DVD/VCR Dual Player
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd player/recorder wont work
I had the same problem with my sansui san0218-160 dvd recorder, i found a capacitor had failed on the power supply board, i replaced the capacitor and it now works perfectly.
Feb 20, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
DVD pauses in the middle of the movie
who ever told you that well... doesnt know dvd players very much no mater what wene ever you watch a movie or anything there is no data transfer back to the cd it is a one way process unless you were burning the dvd which you would not be able to watch it at that time. as for the pausing thing take a soft cloth and clean the cd then get a can of compressed air and blow it into the slots to make sure that it is clean inside the machine. if that does not work then your problem is with the dvd. does it do it with other dvd's or just that one?
Jan 08, 2009 | Pioneer DV-09 DVD Player
Dubbing vhs to dvd
If you try and record a video with copygaurd it will only record a tiny section. If you press stop or return for 3 seconds you will cancel the recording, try pressing the pause button you edit out adverts, i have not tried this yet but it might work.
Dec 31, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Sansui VRDVD5000 DVD Recorder/VCR Logo
21 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
