Question about Gateway Symantec Security 360R Appliance [ Symantec 10224333 ] (113744) Firewall
Lanmanworkstation service automaticaly down. Creates and maintains client network connections to remote servers. If this service is stopped, these connections will be unavailable. If this service is disabled, any services that explicitly depend on it will fail to start. The service dependant are like unable to print and access to another system in LAN.
Smartcard cannot be forwarded to Terminal Server via RDP
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Feb 11, 2014 | Microsoft Windows 7 Professional 64 Bit 3...
After installing SP1 on Windows 7 home basic stopped connecting terminal L230. The client sees the server but when trying to connect an error about can not connect. On the server side I see that the L230...
Not clear whether you installed SP1 on the client or the server.
Try resetting or powering off and on the L230 and let it reintroduce itself to the network.
Also restart the computer that had the SP1 installed on it.
If none of the above resolves the problem, enter Network settings on the client and ensure that Neywork Discovery and File Sharing are not turned off. If they are off, enter Network and Sharing Center and use the Drop Down arrows on the right to turn them and any other desired options on.
Hope this helps.
Aug 24, 2011 | NComputing L230 Network Terminal
Three users of Outlook 2007 shut down their computer and the next time they turn them on, they get the error message "A data file did not close properly" in Outlook and Outlook check's its...
Are you using any trend micro anti virus? If so, try the following
1. Open your Outlook 2007
2. Click on Tools.
3. Click on Trust center.
4. The Trust center window will pop-up and click on Add-ins on the right part of the screen.
5. Under Manage: COM Add-ins
6. Click on Go.. (Middle bottom part of screen)
7. Uncheck all the Add-ins Exept for TMAS (TMAS is Trend Micro) then Click on OK.
7. Restart your computer.
Or if using a anti virus program and you see that in the "add in" options just substitute.
The following link has some problems and solutions for that event ID you gave.
Click here
May 05, 2011 | Computers & Internet
I am trying to downlaod something but i need to wright a proxy sever but i don't know what a proxy sever is or how to do it?
In computer networks, a proxy server is a server (a computer system or an application program) that acts as an intermediary for requests from clients seeking resources from other servers. A client connects to the proxy server, requesting some service, such as a file, connection, web page, or other resource, available from a different server. The proxy server evaluates the request according to its filtering rules. For example, it may filter traffic by IP address or protocol. If the request is validated by the filter, the proxy provides the resource by connecting to the relevant server and requesting the service on behalf of the client. A proxy server may optionally alter the client's request or the server's response, and sometimes it may serve the request without contacting the specified server. In this case, it 'caches' responses from the remote server, and returns subsequent requests for the same content directly.
A proxy server has a large variety of potential purposes, including:
1: To keep machines behind it anonymous (mainly for security.
2: To speed up access to resources (using caching). Web proxies are commonly used to cache web pages from a web server.
3: To apply access policy to network services or content, e.g. to block undesired sites
4: To log / audit usage, i.e. to provide company employee Internet usage reporting
5: To bypass security/ parental controls
Aug 01, 2010 | Computers & Internet
Hi. I want to set up a server and run dumb terminals (thin clients) off of it. Can anyone give me a basic run-down about how I do that?
You would setup Windows Server. Windows Server 2003 and 2008 Small Business Server comes with a license of Terminal Services Server.
You would first need to setup your Windows Server. Install it according to at least minimum requirements.
Make sure you assign this server the correct role. If this is the primary server and if you intend on hosting dns and dhcp on this machine, then please make sure you are assigning this server these roles.
You will need to create user accounts so that you can log into from your thin clients.
Next you need to run the install for Terminal Server.
Next you need to configure each thin client.
Next try to access each thin client via Remote Desktop as well as the server.
This is the basic run down of the process. If you do not know how to setup a server then you will need to ask that question as this is very detailed. Also you will need to be more detailed in your question as to whether this is a linux based network or a windows based network.
Hope this helps. Please don't forget to give me a good rating as well as your vote.
Apr 02, 2010 | Network Computing Devices (NSH800S/A)...
SIte to site vpn/remote desktop
Open up the vpn client any any of the working machine, and then
click on
file>>save Prfoile>>give a name
Take a copy of that and paste it in your machine.
On your machine install the vpn client (Straight Forward Installation). Then
Click on Import Profile , Identify the location where you have pasted the profile (Which is copied from other machine).
You are done with that.
Mar 13, 2009 | Cisco PIX 501 Firewall
Can't send e-mail
Check your network connection. Can you visit web pages? If not, check your network cable, modem, etc.
If your connection is good, try pinging your outgoing mail server.
If the ping fails, phone whoever maintains the server, and ask them when it will be back online.
If the ping is successful, try closing, then opening your mail client. Doublecheck the settings for outgoing server, port, encryption options, username and password.
Sep 17, 2008 | Gateway Computers & Internet
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to 2. Select "Search" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 770
Computers & Internet Logo
2,830 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
