Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
How do i get my files on a usb drive? What format are they in? can i export them? how?
    Problem Solver:
  • 7 Answers
To get files on a drive, all you have to do is copy the files you want. when you've done that, paste them into the drive.
Posted on Feb 20, 2009
How to remove write protect on my usb
On USB sticks there is a small switch which should be unlocked before you attempt to format. That is exactly what the switch is for... to prevent you from formatting and possible deleting valuable information.
Another issue could be
Permissions in the PC may have restricted writing files to the USB flash drive. Disabling restrictions should fix this issue.
WARNING: Backup your registry before editing.
STEP 1 - Backup the registry
1. Unplug the USB flash drive.
2. Click Start > Run, type in regedit then click OK.
3. From the registry menu, click File, select Export.
4. Under Export range select All.
5.Name the file SNDK.reg and save it to the desktop.
STEP 2 - Disable the "Write Protect" permission in the Registry
1. On the left pane, click the "+" beside HKEY_LOCAL_MACHINE
2. Navigate to SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
3. On the right pane, right-click on WriteProtect and select Modify.
4. In the Value data field, type the number 0
5. Click OK.
Nov 25, 2010 | Computers & Internet
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
I HOW I EXPORT TALLY 7.2 DATA IN EXCEL FORMAT
Step 1
Or
Step 2
Step 3
Nov 10, 2010 | Tally T2245 Matrix Printer
Hi expert how do I transfere my outlook account from my old computer to my new computer, both have xp pro. thanks for your help
Open outlook express then go to file menu Import export then select export to .pst file and export data from outlook save that .pst file then copy that file on usb flash drive go to another computer connect usb flash drive then again go to file menu import export then import data from pst file then you can get data on new computer too from outlook. Let me know if you need further assistance. Thanks for using FixYa.
Oct 11, 2010 | Microsoft Outlook
I have a sandisk cruzer micro 512 MB. how do i back up my files to it? thx.
Assuming you use a PC not a Mac and by files you mean things like documents on your computer or emails in MS Outlook.
Connect USB to Computer using a USB Port.
For documents:
  1. Highlight all the files that you want to back up (Holding Ctrl and Clicking)
    (NOTE: MAX of about 500MB in total size)
  2. Press Ctrl and C (or Right Click on a selected file and choose Copy)
  3. Click Start
  4. Click My Computer
  5. Find the USB Drive (usually the E: drive or higher (eg. F:, G:, H:, etc.)) and double click it's icon.
  6. Press Ctrl and V (or Right Click in white area and choose Paste)
  7. Selected Files will appear on USB Drive
  8. Repeat
For Email:
Find the Drive's Name in My Computer (Click Start --> My Computer --> Find Drive (usually e:))
http://support.microsoft.com/kb/287070>
If you want to back up only some of your Outlook data, you can create a new backup .pst file of only the data that you want to save. This is also known as exporting .pst file data. For example, you might want to use this section if you have important information in only some folders and you have other, less important items in much larger folders. You can export only the important folders or contacts and omit folders like Sent Mail.
Follow these steps to export a specific folder:
  1. Open Outlook.
  2. On the File menu, click Import And Export. If the menu item is not available, hover your pointer over the chevrons at the bottom of the menu, and then click Import and Export.
  3. Click Export To File, and then click Next.
  4. Click Personal Folder File (.pst) , and then click Next.
  5. Click the folder that you want to export the .pst file to, and then click Next.
  6. Click Browse, and then select the location where you want the new .pst file to be saved.
  7. In the File Name box, , type the name that you want to use for the new .pst file, and then click OK.
  8. Click Finish.
Files should now be backed up to USB
Oct 09, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Add a excel format in tally
Sir,
What to Export ?
Tally has a facility to export its data to other applications like spreadsheets, word processing software and other database software. Export of data is provided mainly for summaries and statement reports like Trial Balance, Stock Summary, etc. You can export it to another company using Tally that will import it directly.
How to Export?
Thanks
Good Luck
Aug 14, 2009 | Adaptec Computers & Internet
Factory restore
You can export address book:
click File -> Export -> Address Book -> Seleck "Text file(comma separeted values)" -> select folder on your usb drive you want to save address book, click next, select what info about your contacts you want to export.
Apr 26, 2009 | Shuttle XPC SD32G2 Barebone
Backing up outlook emails
1) to export go to File
Export select to format of exported file
select what you want to export
and where.
2) To use with Outlook You can also use autoarchive option:
Tools / Options Others Tab Autoarchive
Or go to folder you want to archive, select properties, Autoarchive tab
Dec 28, 2008 | Microsoft Office Outlook 2003 for PC
Downloading file such as Outlook Express, microsoft word, microsoft excell
>lets open windows address book
>Export the contacts>as Address book (wab)>save it on to desktop and give a file name
>Once it is saved copy and paste it to flash drive
>lets connect the flash drive to another computer
>lets copy the file and paste it to desktop
>lets import the file from desktop
Jul 29, 2008 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Jan 02, 2008 | Tally T2245 Matrix Printer
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
140 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
