Question about Philips FB201SUB Speaker
Philips sw900/17 power subwoofer
How do i hook up this unit to my Direct tv sat box?
Have hooked up system according to manual (I think) using HDMI, to Samsung plasma set. Also have audio cable hooked up (from subwoofer to tv). Get absolutely no sound through system. I imagine I have...
Look on the back of your TV for an HDMI port that has "ARC" on it, connect that to the HDMI Out on the subwoofer. Make sure that your HDMI cable supports ARC. That is the only connection you should need to the subwoofer, remove everything else. Other option is an optical cable between the TV and the Subwoofer.
I just discovered this after fooling around with it for the past couple of days!
Dec 27, 2012 | Samsung HW-E550 Crystal Surround Air Track...
How do i connect my direct tv box to my tv
If hooking up in High Definition: Use HDMI cable from sat to tv.
or component video, or standard sat and standard tv: use a red-white-yellow cable from the sat box to the tv.
Feb 26, 2011 | Televison & Video
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
My philips lcd digital tv says I am recieveing analog signals from a digital direct tv sat. How do I get my tv to change to accept digital signals?
First verify that the direct TV satellite box is set to receive and display digital stations. If you old set on the sat was analog, the box may not have been reset. You may have to contact you satellite provider. Next you will have to go to the TV menu and auto program/scan in the stations. This should pick up all the stations.
Mar 16, 2009 | Philips 32PFL5332D 32 in. LCD Television
Hook cable box to this receiver
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
Let me know if I clearify any of this.
Jan 02, 2009 | Onkyo TX-DS575 Receiver
All of a sudden no picture just snow
Do you have a spare TV? Hook it up to the Sat. box. If you still have no picture, then the Sat. system has a problem. If the sub TV does have a picture, then the problem is on the ProScan end.
May 06, 2008 | Proscan PSVR83 VCR
Dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
Jan 15, 2008 | Philips Magnavox DVD/VCR Dual Player
No Satelite Signal Indication
The "front end" of your Receiver might be defective. Since your other unit is working then what might be happening is the signal to your unit might be dropping, to check this I would use a Satellite power meter, however if you do not have one you can use your other unit and connect it to the cable that your supposed defective unit is connected to. If the unit works then the problem is the supposed defective unit, if the unit does not work then this denotes a possible cable problem. Tell me if this works for you?
Sep 25, 2007 | RCA DRD485RG DirecTV DTV Receiver
543 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
