Question about Jet 1HD Power Electric Wheelchair
Wheel chair will not stayed charged.
I Have a jet 2 HD wheel chair and I charge it every night. But by the time I go around the block in it it has lost its charge. It has been in and been worked on several times. They have put new charger. New batteries. New motors and It still don't work right. The people that I take it to work on medical equipment for a living. But they have no Idea what is causing the problem. I need advice on how to fix this problem. If anyone has this problem with their chair or if anyone knows how to fix it. Please tell me. I am desperate for a way to fix it.
  • 40 Answers
Also sounds like your dealer is not on the level.
Posted on Mar 26, 2009
    Problem Solver:
  • 11 Answers
Something is discharging your battery. Possible the unit have ground fault that cause the battery lost its charge. Try to remove this ground fault & you will solve the unit problem.
Posted on Mar 21, 2009
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
I have a Jet 3 power chair. I recently had 2 new motors and batteries installed. I am having problems with the batteries holding a charge. I charge them every night for 10+ hrs. It shows full charge in the...
yes there is a short either in the motors or joystick u would be better off contacting the dealer and have a tech run his programmer on it and tell u what is wrong, will save u money if u can take that power chair to the dealers shop
Jan 21, 2014 | Jet 3 Ultra Power Chair
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
The Battery does not seem to charge so I want to remove it and see if it will charge if connected to an external charger. How do I remove the said batteries?
Remove the batteries .. Every Chair is different .. but if the batteries aren't charging it's probably that they were left uncharged for a time and they dropped down enough that the charger dosn't recognize them .. If they drop down below around 6 volts the charger won't charge them ... I have taken batteries out and charged them individualy with a car charger .. but they never come back .. at best half life.
Aug 31, 2011 | Pride Mobility Products New Pride Mobility...
Clanklng in left drive wheel
if you block your chair up in the air so your wheel is off the floor you can check for a few things. First roll the wheel around and see if its rubbing. next see if the barrings are out if they are the wheel will woble. next see if the bolt in the center is tight. if you catch this in time it wont cost alot if any money
Jul 06, 2011 | Jet 3 Ultra Power Chair
Need a battery charger for jet model 2904jt-24 3stage
Check around the neighborhood for others who have chairs. Any 4 amp charger for a wheel chair will work for you. You can try E-bay also. Your provider will wanna charge you a good bit for a new charger so check in the neighborhood first to borrow one until you can get one Hope this helps
Aug 22, 2010 | Jet 3 Ultra Power Chair
Jazzy wheel chair
When a chair sits for a long period of time ( four weeks or more) without being charged, the batteries die. To help you with the freewheel mode I would have to know what model of Jazzy it is.
Nov 12, 2009 | Health & Beauty
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Jet 1HD Power Electric Wheelchair Logo
243 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
