Question about Euro-Pro 473
The needle is always broken how can i fix my singer sewing machine model 287
    President:
  • 1,952 Answers
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem
Posted on Feb 19, 2009
Singer Esteem II Model 2273 - Why is my Needle is always REVERSE mode !!
Ah... a plastic Singer. I'm sorry for you. It's likely something broke, take it in for repair.
Mar 19, 2013 | Singer Sewing Machines
My singer HD 110 will sew a bit then suddenly the needle will slow down to a stop & the handwheel seems stuck, yet the motor is still running.
Hello there! Make sure your pattern selector is compatible with the presser foot. Good idea to test with a straight stitch setting: Tension: 4. Width:4-5. Length 5 after you insert a new needle and re-thread machine. Your previous needle may have become bent when machine malfunctioned. Use fabric compatible with needle size. Always raise presser foot when threading! Then always lower presser foot before sewing. Remember to use blue tip scarf needles with synthetic fabric silk thread 50. Purster thread 50, mercerized cotton thread 50-60; #11 or #9 for fine or lightweight fabric with silk thread 50 or fine Pollyester thread; #18 leather needle for leather, #14 - 16 denim . Jimmy Sweep out shuttle carefully with small brush for broken threads and lint.
Mar 31, 2012 | Singer Sewing Machines
I have a Singer Sewing Machine Model 4562 T I
yes you can get help from youtube.
How to Fix / Repair the Hook Timing on a Sewing Machine
Oct 16, 2009 | Singer 132QRFB Mechanical Sewing Machine
Singer sewing machine jammed after sewing over straight pin
The shuttle and needle timing needs to be re-set. Also the hook needs to be inspected for damage.
Oct 14, 2009 | Singer Sewing Machines
Singer 8280 bent needle, now machine wont work
Depends what it would cost for service. Most standard service would cost at least $50-100. You can purchase a replacement machine for ~$100.
Amazon com Singer Sewing Machine Model 8280
Jan 01, 2018 | Singer 8280 Mechanical Sewing Machine
How do I fix a timing problem with my singer sewing machine? The needle thread will not pick up my bobbin thread.
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
May 03, 2008 | Singer 5050 Mechanical Sewing Machine
Euro-Pro 473 Logo
178 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
