Question about GE GSL25JFPBS Side by Side Refrigerator
Water leaking from freezer door.
Water is leaking from the water line entering the bottom of the freezer door.
  • Anonymous Mar 21, 2009
    Water is dripping from the seal at the bottom of my freezer door. It was left open (accidentally) for an hour or so. Now it is closed but still leaking.
Yeay!!! Thank you soooo much!! I opened my freezer door for about 5 minutes and also turned the freezer temp warmer, and my water dispenser worked again. And thanks to you guys, i didn't need my husband's help figuring this out :-)
Posted on Mar 01, 2009
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Why my refrigerator /freezer is leaking water from the bottom front near freezer and water builds up in the bottom of the freezer?
The leak is probably from the small PVC water line leading to the freezer door ice/water dispenser. Manufacturers put a small plastic joiner at that point to allow removal of the door for shipping and installation. That tiny connector can become easily disconnected and leak water onto the floor every time someone presses the water valve in the dispenser. It's easy to fix, Lowes and Home Depot have the fix-it kit for about $5, but you will probably find the existing joiner parts already attached but only needing to be rejoined.
I'll attach a photo of the Home Depot kit. you can also order it from Amazon and have it delivered right to your mailbox. Search for a "refrigerator door water line connector" and you should see a GE part number WR02X11330.
Aug 21, 2014 | Refrigerators
Water leaking from door when cold water dispenser being used
Hello Frank,
The line that runs from under the freezer door and connects to the dispenser is cracked or the connector is cracked. By removing the lower hinge cover ya should be able to see where the line connects to the door and see if it seems to be cracked and leaking their,if that connector is good then the line inside of the door is leaking..in some cases depending on brand the line is easily replacable without having to dis-assamble the entire door
GENE
Nov 11, 2011 | Refrigerators
I have a side by side Kenmore refrigerator model #363-9562510. Water leaks from the bottom right corner of the freezer door from a small round cut out hole. This is the door that has the ice and water...
couple of things to check if you have a dispenser on this model there is a hose that goes up into the bottom of the freezer door you need to remove bottom kick plate and take a look at this...also if no water from that hose and its actually coming from the door you could have a ruptured line in the door itself.... next make sure the water is not actually coming from the freezer compartment as the drain in the freezer could be clooged and leaking over on defrost mode and out door...
hope this helps good luck...
Jan 05, 2011 | Kenmore Refrigerators
While water is being dispensed through the cool water outlet, water leaks thru the flexable line at the bottom of the freezer compartment door. Whats the problem, and how can it be fixed?
Due to water comming from the bottom of the dooe , you will need to replace the door water line . Pt # WR17X10206 is the replacement line . Remove the upper portion and " feed " the new line down thru the freezer door .
May 30, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking at bottom of freezer door where water line goes into door
DRAIN IS STOPPED UP! IS THIS A TOP AND BOTTOM OR A SIDE X SIDE?
Apr 27, 2009 | Freezers
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Aug 25, 2008 | KitchenAid Superba Architect KSCS25INSS...
GE GSL25JFPBS Side by Side Refrigerator Logo
356 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
