Question about Kenmore Refrigerators
Freezor barely freezing, fridge barely cooling
It may be coincidental but our power was out for 6 days. Not long after it came back I noticed my fridge was not cooling well. Then the freezor wasn't doing so well. It is still producing ice but things in the freezor are not as solid as before (frozen). The fan underneath is running constantly. I took the sheild off from inside freezor and the evaporator was covered in frost. I plugged it back in to see if evap fan ran and it did. I am currently letting it defrost but need help in how to fix the problem. I doubt I'm lucky enough for it to work right just by defrosting it. Thanks in advance for any input.
  • kornbread3 Feb 19, 2009
    It typically stays about 5. I happened to read something about rotating the defrost timer a little clockwise. I did that and am just gonna let it defrost good over night. I guess when I plug it back in, in the morning I'll set it at 5 and the compressor should kick on, correct? I guess if that's right and it doesn't then my compressor is bad? Would the thing stay cool at all if it was bad, though?
    Thanks for the feedback, I welcome any more.
  • 150 Answers
After the electricity came on what setting did you use? I would start out at 4 or 5.When a unit sits too long without running the coolant will settle to the bottom it can be hard on it because it is trying to push it threw the system.After it defrosts all the lines should be clear. From there it could be as simple as the fan in the freezer is slowing down or your compressor is on its way out. Also check the vent from the freezer to the fridge for blockage.
Len
Posted on Feb 19, 2009
  • Len West
    Len West Feb 19, 2009
    Let me know.
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
Freezor frosts up in side a lot snow flaky and ice build up
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
The freezor is cold but the refrigerator part is not cold.
heatman101
Apr 30, 2011 | Whirlpool Refrigerators
Water running from underneath the freezor onto the floor. Water pooling in the bottom of the freezor.
heatman101
Mar 30, 2011 | Amana ABB1927DE Bottom Freezer...
Water leaking from freezor side
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Frigidaire FRS26R4A Side by Side...
Not cooling at all
Either the compressor has seized or refrigerant gas has all leaked away are the two most likely and expensive reasons!
Mar 21, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge and freezer are not cooling well
hi.
If the evaporator fan isn't working, that's probably the problem. Test here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
thank u
rate me!!
Jul 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Dometic refrigerator freezing in bottom
Move your thermistor closer to the center. Your thermistor is attached to the fins on the inside of the fridge. Also turn off the fridge and take the circuit board cover off and make sure that the thermistor cable is plugged in. the cable is a 2 wire terminal will be on upper right or upper left of the circuit board just below the 6 pin connector.There is another possibility but remote. The cooling unit may be getting ready to stop working. Have had many customers tell me that the fridge started freezing up and a few days later quit working completely.
Hope this helps you.
Mar 20, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
