Question about Whirlpool Duet GHW9150P Front Load Washer
Drum does not spin fast anymore
Have a front load washer and the motor will spin it, but not fast so the clothes are all still soaked when done.  Have not noticed an error code at all. Whirlpool Duet washer spins, but clothes are not spun very dry. Can still wring out water from them by hand, and they take about 1.75 hours to dry in dryer. No error codes.
  • 15,935 Answers
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Wont spin
have you cleaned the filter
if you have
change the motor brushes
Mar 10, 2014 | Hotpoint Aquarius WD63 Front Load...
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
there s a"button trap" located on the side of your pump assy, behind the lower acess panel ( youll need to remove 3 torx 20 screws from the from bottom of machine ) after emoving the panel oull see the clean out directly in forn t of you. BE WARNED THERE WILL BE WATER behind that acess point grab a towle!!!!
cloges with debris and such preventing good draining!!
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore spin cycle issues
Does it agitate and spin at the same time? the motor has a pump on one side and gear case on the other. if the gear case is seizing then the pump is lagging because the motor is loaded from a seizing gearcase and the gear case needs to be replaced.
Aug 24, 2008 | Kenmore 24032\24036 Top Load Washer
Hotpoint WD440
Bad door latch or Control board is bad
Apr 28, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
94 people viewed this question
Dan Webster
Dan Webster
Sal De
