Question about Frigidaire GLTF1670A Front Load Washer
When my washer goes into fast spin it is very loud could it be a bearing?
  • tjayrogers58 Feb 20, 2009
    Thanks for the advice thats what i was thinking also .Any idea of the cost of the part?
  • 188 Answers
If it sounds like it's growling or rumbling it's definitely the bearing.
The rear shell of the tub which includes the bearing will need to be replaced since the bearing is not serviceable on it's own.
It's going to get worse until it fails completely.
In the future, make sure you are using HE (high efficiency) detergent. About 2 tablespoons for a full load is enough.
Posted on Feb 19, 2009
  • Paulo Feb 21, 2009
    rear shell w/ bearing is ~$200
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Hi When spin drying or any fast spin cycle it has a very loud rough bearing type of noise
sounds like main tub bearings are gone ..turn the drum by hand if it rumbles its bearing dont use it ... this is not a good job to do.
Feb 27, 2011 | Amana NAV5800AW Top Load Washer
Noise when is spinning
Could be a bearing, or perhaps vibration Check concrete weight are tight , springs okay.Machine is level..please leave feedback.
Apr 07, 2010 | Kenmore 45981 Washer
My washer sounds like an airplane taking off when in spin cycle. It is really loud.
its probebly the main bearing. disconect the power and remove the back. then slide the belt off the big pulley. if you see alot of brown splatter you know its the bearing.if not with the belt removed go to the front and open the door spin the drum fast, if it makes the same noise its the rear bearing.
Jan 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud sounds coming from the washer on spin cycle
That is a characteristic of bearings gone bad. You should look into replacing the bearings.
Mar 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
106 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
