Question about Samsung DVD-VR375 DVD Recorder/VCR
Audio and video are about 3 sec. out of synch
When I dub from VHS to DVD, the audio and video on the disk are about 3 sec. out of synch. Is there anyway to fix this?I have the same problem with audio and video being out of sync and I tried the solution suggested of using a -R x8. The result was the same. The sync was still off. Is there another potential solution?
  • 3,037 Answers
Hi William
It is a problem with the device hardware itself. Try exchanging it or just returning it and get a different brand. You aren't the only one who has had this problem. I have seen it before a few times.
Benjamin
Posted on Feb 19, 2009
    Genius:
  • 1,550 Answers
Probable there is no solution for your problem . Better take to samsung service center they may upgrade firmware for your product .
You face this problem due to
  • Improper sync in audio/video encoding or DVD-Video formatting.
  • Loose sync tolerances in the player.
    President:
  • 1,952 Answers
Samsung to use a -r 8x disk.
  • 2 more comments
  • mohammed marika thambi
    mohammed marika thambi Feb 19, 2009
    Try capturing with VirtualDubMod - it's a known problem that many
    capture devices don't maintain audio/video synch, but VirtualDubMod
    usually keeps it.
    Try doing an Output Production to a DV AVI file rather than a MPEG.
    Bring the DV AVI file into DVDBuilder and burn to disc. It does not
    work for all users with the problem
    Finally I did two things that made it work (don't know which fixed
    it) - I downloaded and installed the update to 7.0, and also, when I
    burned it to DVD, I went into the burn settings and picked the other
    audio option. I don't have Roxio here on my work computer, but there
    were two options for the audio (I think the first was Dolby) and I
    picked the second, non-default one that said something like More
    compatible, less compression, but larger file sizes. From then on, it's
    been fine.
  • 547 Answers
I don't think you can unless you get a program you can set it up your self if it's 3 sec's out then it's out the device you are useing reads it that way and will keep doing so sorry
  • 679 Answers
Use a high speed disk.
  • rockfixya
    rockfixya Feb 19, 2009
    for more info. go to the link>>
    http://www.howtodothings.com/computers/a...
  • rockfixya
    If the problem persists than reset the DVD?VCR Combo.....
    Press and hold the input select and record mode bottons for 15 seconds then turn off player and it will start up in factory when you turn it on.
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
When I dub a vhs tape to DVD-R I'm getting a consistent
The 'BOUGHT VHS TAPES" have a copy guard on them- your home made ones do not
Jun 02, 2008 | Televison & Video
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Problems dubbing from hard drive to DVD RW disk
Switch CD R or DVD R
RW disks are not suitable for this work.
Dec 17, 2007 | Computers & Internet
DUBBING ONTO VHS FROM DVD
if you have two separate units, the best way is to connect s-video cable from the output of the dvd player to the input of the vcr. If not, second best is to connect the video/audio out of the dvd to the video/audio in of the vcr. Othwise the units may have a rf (75 ohm cable) output and the dvd usually sends channel 3 or channel 4 as an output when playing and the vcr must be tuned to this channel. Start the dvd, pause it, hit the vcr record button, then unpause the dvd.
Nov 30, 2007 | Emerson EWR20V4 DVD Recorder/VCR
VCR to DVD Dub Out of Synch
FIRST THING YOU HAVE TO DO IS HAVE YOUR DVD RECORDERS LENS AND DRIVE CLEANED ALSO MAKE SURE THE VCR HEADS ARE CLEANED ALSO.
NEXT WHEN RECORDING make sure the format of the tape(speed like sp & lp are the same as the dvd recording speed(sp& lp are the same before starting recording.
Nov 20, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
Problem dubbing from VHS to DVD
Try different brands of disk, most dvd-r recorder are disk sensitive, buy only one disk per brand, find the brand compatible to your recorder by just inserting the disk and wait for confirmation that it is ready for recording session. I have tried around five brands, sony and maxell as well as verbatim are good dvd-r disk.
Aug 23, 2007 | Sony RDR-VX555
Samsung DVD-VR375 DVD Recorder/VCR Logo
Jerry Greenberg
Jerry Greenberg
