Question about Philips Audio Players & Recorders
I'm looking for a user manual for a Philips SW900/17 Power sub woofer.I want to add it to my Home theatre system.Direct tv box is a mod # HR-21-100.I want to hook it up through my sat box.
Hey
did you find the solution?
I have same system and I am stuck too
please help
Posted on Aug 19, 2009
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
Can I replace my Philips LX80000SA integrated home theatre with any active subwoofer?
yes you can. When comparing the subwoofer I would look at it's Ohms, typically it's 4 or 8, anything higher sounds weaker. the lower the better. power is measured in watts also compare the old woofer with your new.
Mar 14, 2010 | Philips LX8000SA System
Philips dvd home theather,i didn't get a users manual,i can't get the sound to come out with the tv,it will owrk with the radio. lloyd
I will guide you through it.
Just to clarify, When you say sound out with the tv, which are you referring to:
1. DVD built into to the theatre
2. Pay TV
3. Analogue TV ( or digital TV with inbuilt set top box)
4.Digital TV with a separate set top box
Please indicate which one.
TV: ther should be several set of three RCA Sockets on the back of the tv. Look for the red, whit and yellow Phono sockets. do you have these colours and are any of them labelled TV Out or output?
Philips System: Look for an analogue in, Aux IN, or any other unused RCA (Phono) Sockets ( They MUST be red or white!)
Take a set of red and white RCA leads plug them into the OUT set on the TV, and The "INput" set on the Home theatre, select that input on the theatre and your off and racing!
Please clarify first though!
Jan 17, 2010 | Philips Audio Players & Recorders
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
I bought philips 5.1 home theatre for PC it is not supporting
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Jul 02, 2008 | Philips HTS3450 System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
131 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
