Question about Fuji Finepix S9600 Digital Camera
How do i get the RAW images
Hi i took some photos in raw and i am trying to get them onto my laptop but there not supported i dont have the disk. any help
    Problem Solver:
  • 12 Answers
If your camera is fairly new, it should have a usb port on it as most new digital cameras do. If so then when you plug it into your pc, the pc will open up a shared directory from your camera and you should be able to drag and drop the pictures over.
If not then if you have an external sd card then you should be able to remove the sd card and put it in a card reader on the pc and when you do, the windows os will show the sd card as another drive and you can pull the pictures across that way.
HTH.
Posted on Feb 19, 2009
I bought a cannon camera EOS 70D, when i use PhotoShop Elements 10, i cannot open the image if the image was taken in RAW.
Hi found a manual for PhotoShop Elements 10 here:
http://help.adobe.com/en_US/photoshopelements/using/photoshopelements_10_help.pdf
It is a pdf file which can be saved to disk for future reference and contains (page 53) a paragraph below:
"Prefer Adobe Camera Raw For Supported Raw Files Ensures that all the supported raw files are opened with Adobe
Camera Raw instead of other software. Select this option if you have added other plug-ins to Plug-Ins folder"
It may be that you have to load the relevant plug-in in order to load these files, or load this plug-in before attempting to load the RAW file.
Hope this helps
Nov 17, 2014 | Cannon Cameras
Raw Format Ooops
hi there,
you can use a memory card reader, if your camera software was faulty to use..
Thank you
May 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
How do i download raw images from my Canon to I photo. Normally no problem with jpegs, now starting to shoot only in Raw
iPhoto isn't the greatest when it comes to dealing with RAW images, but it can:
iPhoto 11 Edit RAW format photos
I would recommend a more powerful photo editor such as Lightroom or something similar.
Aug 24, 2014 | Computers & Internet
On screen IN CARD FULL only took 13 photos no more on card
You can buy larger capacity cards and set your camera for JPEG
not RAW raw takes up alot of room on card
Jul 11, 2014 | Fuji FinePix F470 Digital Camera
Importing Images
The CR2 suffix means that the picture was taken in the RAW file format, a proprietary format. This requires that the images be processed by a software conversion to be 'readable' by the computer. The EOS Utility software that came with the camera will work, as well as a number of third-party software packages. GOOGLE "raw file conversion Canon digital rebel" to see the options.
The other option is to take your photos in JPEG format (not RAW). Your computer can 'read' any JPEG format image.
Feb 28, 2010 | Canon Digital Rebel / EOS-300D Digital...
I'm trying to recover 155 RAW photo images from my Lexar sdhc 4gb memory card .I'v tryed 2 differant photo stores but they could not help me ...we could look at the images but not get them off the card or...
you can try this memory card recovery software called asoftech photo recovery that helped me before
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Sep 19, 2009 | Lexar Professional High-Speed 2GB Secure...
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
I'm unable to download photos from the disk.
You may be saving the images in the RAW format, which requires matching software to read. Most kiosks can't read them. If this is the case, switch back to jpeg format.
Mar 19, 2009 | Canon PowerShot G9 Digital Camera
RAW images won't upload
Are you using the camera to upload the photos? I recommend that you get a SDHC reader(USB) and copy the files off of the SD card onto your harddrive. it is a common problem that RAW images cannot be read by windows or certain programs. Photoshop CS3 and later are able to read and open the RAW images from this camera if your "camera raw" portion of adobe is current. it is good practice anyway to load your photos directly from the SD card. I had a G9 since it first came out and now i have a G10--i have never even attempted to upload from the camera. don't let this discourage you from shooting RAW because it is the primary reason in my opinion for owning a G9 or G10. Let me know if this does not answer your problem...dj
Jan 17, 2009 | Canon PowerShot G9 Digital Camera
EOS 400D Digital Camera Software
Hi
If you bought your camera (400D) new it would have come with RAW conversion software on a disk. You can start by installing this. To get the photos off the camera you should be able to plug it in vis the USB cable that came with it. The better way would be to buy a card reader. This is a lot quicker, save on battery wear and tear, or save you plugging in the power.
Alternative software would be to buy Adobe Photoshop Elements for the RAW processing. This is a good start for most people.
Regards
Jul 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Fuji Finepix S9600 Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
